Atmle计量介绍
734|0
 楼主| ddllxxrr 发表于 2015-8-17 21:44 | 显示全部楼层 |阅读模式
ATM, TE, AN, ic, ce
计量
Atmel的系列IC智能电表的功能最宽的动态范围,在行业以及极高的精确度,从而有助于提高智能电表的性能。该芯片拥有6000动态范围:1。这使得制造商能够各种类型的当前可用米,如5(20)A,10(40)A,15(60)A和20(80)A,合并成一个标准模型[5(100),A或1 (100)A]。爱特梅尔芯片将简化制造工艺,降低整个物料。
关键特性
单和多相解的0.2级精度。
6000:1动态范围提高性能和降低材料的制造和比尔OEM的整体成本。
符合IEC62052-11和,iec62053-22 / 23,ANSI c12.1,c12.20。
最佳的类的温度系数在工业上的这种类型的设备
Device Family
Summary Benefit
Applications
Technologies
Key Parameters
Metering AFEs
Hardware Metrology AFE
Up to class 0.2 accuracy
Best-in-class temperature coefficient
Best-in-class dynamic range (up to 6000:1)
Energy meters
Power monitoring instruments
Accuracy of ±0.1% for active energy and ±0.2% for reactive energy over a dynamic range of 6000:1
High stability on-chip reference voltage with best-in-class temperature coefficient
Dynamic Range: 6000:1
Temperature Coefficient (ppm/°C): 6
Active Energy Accuracy: 0.1 %
Reactive Energy Accuracy: 0.2 %
[url=]Details[/url]
Dual Core MCU and Companion AFE
SAM4Cx: dual high performance 32-bit ARM Cortex-M4 core with maximum speed of 120 MHz, up to 2Mbyte of embedded Flash, 304 Kbytes of SRAM, and advanced security
ATSENSE: Analog Front End (AFE) devices with up to 7 channels of high-precision sigma-delta ADCs with a 16ksps sample rate, a highly accurate, integrated Vref with 10 ppm/°C temperature stability, programmable current signal amplification, a temperature sensor and an SPI interface.
Electricity Meters
Gas and Water Meters
Data Concentrators
In-Home Display Units
High performance 32-bit, dual core ARM® Cortex®-M4 processor
Embedded cryptographic engine and dedicated 128-bit Advanced Encryption Standard (AES) hardware block
Dual 32-bit ARM Cortex-M4
Maximum speed of 120 MHz
Up to 2 Mbytes of Flash
Up to 304 Kbytes of SRAM
Advanced cryptographic engine
USB Full-speed Host/Device port
Up to 5 USARTs, 2 UARTs
50 × 6 segmented LCD controller
[url=]Details[/url]
Dual Core Metering SoC
System-on-chip for metering applications up to class 0.2 metrology accuracy over a dynamic range of 3000:1
Firmware metrology enabled device offer an unprecedented level of integration and flexibility with dual 32-bit ARM Cortex-M4 cores providing maximum speed of 120 MHz each, 2Mbytes of embedded Flash, 304 Kbytes of SRAM
Electricity Meters
Data Concentrators
Highly accurate, integrated Vref with 10 ppm/°C temperature stability
Proven firmware metrology library
Maximum speed 120 MHz
Up to 4 USARTs, 2 UARTs
38 × 6 segmented LCD controller
4/7 channels of sigma-delta ADCs
[url=]Details[/url]
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2404
