- #include <asf.h>
- #define AES_EXAMPLE_REFBUF_SIZE 4
- uint32_t ref_plain_text[AES_EXAMPLE_REFBUF_SIZE] = {
- 0xe2bec16b,
- 0x969f402e,
- 0x117e3de9,
- 0x2a179373
- uint32_t ref_cipher_text_ecb[AES_EXAMPLE_REFBUF_SIZE] = {
- 0xb47bd73a,
- 0x60367a0d,
- 0xf3ca9ea8,
- 0x97ef6624
- uint32_t ref_cipher_text_cbc[AES_EXAMPLE_REFBUF_SIZE] = {
- 0xacab4976,
- 0x46b21981,
- 0x9b8ee9ce,
- 0x7d19e912
- uint32_t ref_cipher_text_cfb128[AES_EXAMPLE_REFBUF_SIZE] = {
- 0x2ed93f3b,
- 0x20ad2db7,
- 0xf8493433,
- 0x4afb3ce8
- uint32_t ref_cipher_text_ofb[AES_EXAMPLE_REFBUF_SIZE] = {
- 0x2ed93f3b,
- 0x20ad2db7,
- 0xf8493433,
- 0x4afb3ce8
- uint32_t ref_cipher_text_ctr[AES_EXAMPLE_REFBUF_SIZE] = {
- 0x91614d87,
- 0x26e320b6,
- 0x6468ef1b,
- 0xceb60d99
- const uint32_t key128[4] = {
- 0x16157e2b,
- 0xa6d2ae28,
- 0x8815f7ab,
- 0x3c4fcf09
- const uint32_t init_vector[4] = {
- 0x03020100,
- 0x07060504,
- 0x0b0a0908,
- 0x0f0e0d0c
- const uint32_t init_vector_ctr[4] = {
- 0xf3f2f1f0,
- 0xf7f6f5f4,
- 0xfbfaf9f8,
- 0xfffefdfc
- /* Output data array */
- static uint32_t output_data[AES_EXAMPLE_REFBUF_SIZE];
- /* State indicate */
- volatile bool state = false;
- struct aes_config g_aes_cfg;
- struct aes_module aes_instance;
- struct usart_module usart_instance;
- static void configure_usart(void)
- struct usart_config config_usart;
- usart_get_config_defaults(&config_usart);
- config_usart.baudrate = 38400;
- config_usart.mux_setting = EDBG_CDC_SERCOM_MUX_SETTING;
- config_usart.pinmux_pad0 = EDBG_CDC_SERCOM_PINMUX_PAD0;
- config_usart.pinmux_pad1 = EDBG_CDC_SERCOM_PINMUX_PAD1;
- config_usart.pinmux_pad2 = EDBG_CDC_SERCOM_PINMUX_PAD2;
- config_usart.pinmux_pad3 = EDBG_CDC_SERCOM_PINMUX_PAD3;
- stdio_serial_init(&usart_instance, EDBG_CDC_MODULE, &config_usart);
- usart_enable(&usart_instance);
- static void aes_callback(void)
- /* Read the output. */
- aes_read_output_data(&aes_instance, output_data);
- state = true;
- static void ecb_mode_test(void)
- printf("\r\n-----------------------------------\r\n");
- printf("- 128bit cryptographic key\r\n");
- printf("- ECB cipher mode\r\n");
- printf("- Auto start mode\r\n");
- printf("- 4 32bit words\r\n");
- printf("-----------------------------------\r\n");
- state = false;
- /* Configure the AES. */
- g_aes_cfg.encrypt_mode = AES_ENCRYPTION;
- g_aes_cfg.key_size = AES_KEY_SIZE_128;
- g_aes_cfg.start_mode = AES_AUTO_START;
- g_aes_cfg.opmode = AES_ECB_MODE;
- g_aes_cfg.cfb_size = AES_CFB_SIZE_128;
- g_aes_cfg.lod = false;
- aes_set_config(&aes_instance,AES, &g_aes_cfg);
- /* Set the cryptographic key. */
- aes_write_key(&aes_instance, key128);
- /* The initialization vector is not used by the ECB cipher mode. */
- aes_set_new_message(&aes_instance);
- /* Write the data to be ciphered to the input data registers. */
- aes_write_input_data(&aes_instance, ref_plain_text);
- aes_clear_new_message(&aes_instance);
- /* Wait for the end of the encryption process. */
- while (false == state) {
- if ((ref_cipher_text_ecb[0] != output_data[0]) ||
- (ref_cipher_text_ecb[1] != output_data[1]) ||
- (ref_cipher_text_ecb[2] != output_data[2]) ||
- (ref_cipher_text_ecb[3] != output_data[3])) {
- printf("\r\nKO!!!\r\n");
- } else {
- printf("\r\nOK!!!\r\n");
- printf("- ECB decipher mode\r\n");
- state = false;
- g_aes_cfg.encrypt_mode = AES_DECRYPTION;
- /* Write the data to be deciphered to the input data registers. */
- aes_write_input_data(&aes_instance, ref_cipher_text_ecb);
- /* Wait for the end of the decryption process. */
- /* check the result. */
- if ((ref_plain_text[0] != output_data[0]) ||
- (ref_plain_text[1] != output_data[1]) ||
- (ref_plain_text[2] != output_data[2]) ||
- (ref_plain_text[3] != output_data[3])) {
- } else {
- static void cbc_mode_test(void)
- printf("- CBC cipher mode\r\n");
- state = false;
- g_aes_cfg.start_mode = AES_MANUAL_START;
- g_aes_cfg.opmode = AES_CBC_MODE;
- /* Set the initialization vector. */
- aes_write_init_vector(&aes_instance, init_vector);
- aes_start(&aes_instance);
- if ((ref_cipher_text_cbc[0] != output_data[0]) ||
- (ref_cipher_text_cbc[1] != output_data[1]) ||
- (ref_cipher_text_cbc[2] != output_data[2]) ||
- (ref_cipher_text_cbc[3] != output_data[3])) {
- } else {
- printf("- CBC decipher mode\r\n");
- state = false;
- aes_write_input_data(&aes_instance, ref_cipher_text_cbc);
- } else {
- static void cfb128_mode_test(void)
- printf("- CFB128 cipher mode\r\n");
- state = false;
- g_aes_cfg.opmode = AES_CFB_MODE;
- if ((ref_cipher_text_cfb128[0] != output_data[0]) ||
- (ref_cipher_text_cfb128[1] != output_data[1]) ||
- (ref_cipher_text_cfb128[2] != output_data[2]) ||
- (ref_cipher_text_cfb128[3] != output_data[3])) {
- } else {
- printf("- CFB128 decipher mode\r\n");
- state = false;
- aes_write_input_data(&aes_instance, ref_cipher_text_cfb128);
- } else {
- static void ofb_mode_test(void)
- printf("- OFB cipher mode\r\n");
- state = false;
- g_aes_cfg.opmode = AES_OFB_MODE;
- if ((ref_cipher_text_ofb[0] != output_data[0]) ||
- (ref_cipher_text_ofb[1] != output_data[1]) ||
- (ref_cipher_text_ofb[2] != output_data[2]) ||
- (ref_cipher_text_ofb[3] != output_data[3])) {
- } else {
- printf("- OFB decipher mode\r\n");
- state = false;
- aes_write_input_data(&aes_instance, ref_cipher_text_ofb);
- } else {
- static void ctr_mode_test(void)
- printf("- CTR cipher mode\r\n");
- state = false;
- g_aes_cfg.opmode = AES_CTR_MODE;
- aes_write_init_vector(&aes_instance, init_vector_ctr);
- if ((ref_cipher_text_ctr[0] != output_data[0]) ||
- (ref_cipher_text_ctr[1] != output_data[1]) ||
- (ref_cipher_text_ctr[2] != output_data[2]) ||
- (ref_cipher_text_ctr[3] != output_data[3])) {
- } else {
- printf("- CTR decipher mode\r\n");
- state = false;
- aes_write_input_data(&aes_instance, ref_cipher_text_ctr);
- } else {
- int main (void)
- /* Initialize the system and console*/
- system_init();
- configure_usart();
- aes_get_config_defaults(&g_aes_cfg);
- aes_init(&aes_instance,AES, &g_aes_cfg);
- aes_enable(&aes_instance);
- /* Enable AES interrupt. */
- aes_register_callback(aes_callback,AES_CALLBACK_ENCRYPTION_COMPLETE);
- aes_enable_callback(&aes_instance,AES_CALLBACK_ENCRYPTION_COMPLETE);
- ecb_mode_test();
- cbc_mode_test();
- cfb128_mode_test();
- ofb_mode_test();
- ctr_mode_test();
执行的结果如下:
