28031仿真出错
1012|3
jiajs|  楼主 | 2015-8-18 21:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
错误提示:
C28xx: Failed Software Reset: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.0.681.0)
C28xx: Trouble Reading PC Register: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.0.681.0)
C28xx: Trouble Reading Register ST1: (Error -1137 @ 0x6) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.0.681.0)
C28xx: GEL: Error while executing OnReset(1): target access failed  at (ST1&~(0x0100)) [f28031.gel:282]  at C28x_Mode() [f28031.gel:32]  at OnReset(1) .
C28xx: Flash Programmer: Error erasing flash memory. Device is locked or not connected. Operation cancelled
C28xx: Flash Programmer: Error erasing Flash memory.
C28xx: Error resuming a profile counter: (Error -1137 @ 0xAE8) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.0.681.0)
C28xx: Flash Programmer: Device is locked or not connected. Operation cancelled.
C28xx: Trouble Writing Memory Block at 0x3f75f6 on Page 0 of Length 0x16: (Error -1137 @ 0xAE8) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.0.681.0)
C28xx: GEL: File: C:\ti\tidcs\c28\DSP2803x\v121\DSP2803x_examples\cpu_timer\Debug\Example_2803xCpuTimer.out: Load failed.
zhanghqi| | 2015-8-18 21:40 | 只看该作者
帮你顶一个   这一块  真心没有用过  希望有高人出现  顶一个  呵呵
zhenykun| | 2015-8-18 21:40 | 只看该作者
有没有可能软件CCS出问题了,重启一下软件试一下。
jiajs|  楼主 | 2015-8-18 21:41 | 只看该作者
试过了,不行
