仿真下载程序时出错
649|3
zhenykun|  楼主 | 2015-8-18 21:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
连接目标之后,下载.out,出错。提示如下:
Error:
Error 0x80000022/-1143
Fatal Error during: Memory, Execution,
The memory at 0x00000400 continually indicated it was 'not ready'
All memory operations currently in progress were aborted in order
to regain control of the processor.
This is considered a catastrophic event, but the debugger should
still be able to access memory and CPU registers.
System state has been altered.  It is strongly advised
that the processor should be reset before resuming execution,
wyjie| | 2015-8-18 21:46 | 只看该作者
个人觉得是存储器的分配出错了
jlyuan| | 2015-8-18 21:46 | 只看该作者
楼上正解
zhenykun|  楼主 | 2015-8-18 21:46 | 只看该作者
大家给点建议。谢谢
