[i.MX] IMX6Q VPU 编码帧率修改问题
2624|4
 楼主| zhanzheng5350 发表于 2015-8-19 16:13 | 显示全部楼层 |阅读模式
大家好,
       我在用mxc_vpu_test.out 进行H.264编码并修改帧率时,得到的编码文件用ffmpeg查看都是25fps
  请问是什么原因
ffmpeg version 0.8.17-4:0.8.17-0ubuntu0.12.04.1, Copyright (c) 2000-2014 the Libav developers
  built on Mar 16 2015 13:26:50 with gcc 4.6.3
The ffmpeg program is only provided for script compatibility and will be removed
in a future release. It has been deprecated in the Libav project to allow for
incompatible command line syntax improvements in its replacement called avconv
(see Changelog for details). Please use avconv instead.
[h264 @ 0x16057a0] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 2400000.00 (2400000/1) -> 25.00 (25/1)
Input #0, h264, from 'mipi_test.264':
  Duration: N/A, bitrate: N/A
    Stream #0.0: Video: h264 (Constrained Baseline), yuv420p, 1280x720, 25 fps, 25 tbr, 1200k tbn, 2400k tbc
At least one output file must be specified
FSL_TICS_Rita 发表于 2015-8-20 09:24 | 显示全部楼层
楼主你好,请问你这里使用的是哪个平台,使用的是哪个版本的BSP 呢?
 楼主| zhanzheng5350 发表于 2015-8-24 16:53 | 显示全部楼层
你好,我使用的I.MX6Q  sabreasd    内核版本:3.10.17
FSL_TICS_Rita 发表于 2015-9-8 15:18 | 显示全部楼层
楼主你好,请问你这里可以给我你的测试步骤吗?你如何修改的 framerate?你这里有试过别的media files吗?是不是也是一样的结果呢?还有你这里的测试都是基于gstreamer上的吗?
mini1986 发表于 2015-9-10 11:02 | 显示全部楼层
关注一下,后续学习学习......
