Sun Apr 29 15:51:45 2007: J-Link firmware: V1.20 (J-Link compiled Mar 22 2007 16:08:22 ARM Rev.5) Sun Apr 29 15:51:45 2007: JTAG speed is initially set to: 32 kHz Sun Apr 29 15:51:45 2007: Resetting target using RESET pin Sun Apr 29 15:51:45 2007: Hardware reset with strategy 0 was performed Sun Apr 29 15:51:45 2007: Initial reset was performed Sun Apr 29 15:51:45 2007: J-Link found 1 JTAG device. ARM core Id: 3F0F0F0F(ARM7) Sun Apr 29 15:51:45 2007: Device at TAP0 selected Sun Apr 29 15:51:45 2007: Auto JTAG speed: 8000 kHz Sun Apr 29 15:51:45 2007: Auto JTAG speed: 8000 kHz Sun Apr 29 15:51:46 2007: 688 bytes downloaded and verified (1.13 Kbytes/sec) Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x000080C8 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x000080CC Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x000080D0 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x000080D2 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x000080E8 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008128 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x0000812C Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008130 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008132 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008150 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008158 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x0000815A Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008160 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x0000817D Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008180 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008182 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x000081A4 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008242 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008001 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008004 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008038 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008244 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008248 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x0000824E Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x000082A4 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x0000825C Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008268 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008281 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00000020 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008042 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x0000806C Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008078 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008080 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008094 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x000080A4 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x000080B8 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008298 Sun Apr 29 15:51:46 2007: There were warnings during download, see Log Window Sun Apr 29 15:51:49 2007: Loaded debugee: C:\Documents and Settings\Administrator\My Documents\LED\Debug\Exe\led.d79 Sun Apr 29 15:51:49 2007: Target reset Sun Apr 29 15:52:20 2007: The stack 'CSTACK' is filled to 100% (8192 bytes used out of 8192). The warning threshold is set to 90%. Sun Apr 29 15:52:20 2007: The stack 'IRQ_STACK' is filled to 100% (256 bytes used out of 256). The warning threshold is set to 90%.
