[开发工具] RealView MDK 3.20 版最新发布!简体中文帮助
4499|8
 楼主| 小野狼 发表于 2008-2-16 14:20 | 显示全部楼层 |阅读模式
RealView MDK最新版本,帮助为简体中文版,下载请前往http://www.realview.com.cn/down-list.asp?id=326
3.20版更新如下:
[Device Support]
    Added: RTX support for TMS470 in folder ..ARMBoardsTITMS470R1B1MRTX_Blinky.
    Added: example projects for NXP LPC2919 in folder ..ARMBoardsKeilMCB2900.
    Added: support for STMicroelectronics STA2051.
    Added: support for AustriaMicroSystems AS3525  in folder ..ARMBoardsAMSAS3525.
    Added: support for NXP (Sharp) LH79524 in folder ..ARMBoardsNXPLH79524.
    Added: support for Winbond W90P710 in folder ..ARMBoardsWinbondW90P710.
    Added: RTX Traffic example for STR9 devices and corrected a problem with the interrupt controlled UART simulation of STR9.
    Corrected: for Altera Cortex-M1 driver the option Use Reset at Startup was not stored.
    Corrected: RT-Agent configuration AT91SAM7X with interrupts in folder ..ARMRT AgentRTXAT91SAM7X-EKBlinky.
    Corrected: Timer3 and Timer4 of LPC2101/2/3 devices was incorrectly simulated.
[RTX - Problems Solved]
    Corrected: core problems for Cortex-M devices. Handling of isr_xxx function calls was incorrect and could cause task locks. Wrong handling of task switches and __svc functions could cause sporadic application crashes if additional user interrupts were enabled.
相关链接:http://www.realview.com.cn/product/271.htm
end2000 发表于 2008-2-17 10:22 | 显示全部楼层
升级很频繁啊
不过对于STM32,现在的3.15b版本我觉得还不错,暂时不打算升级了。
qjy_dali 发表于 2008-2-18 00:24 | 显示全部楼层
帮助是中文的,这对很多用户应该很有用啊
rogetxu 发表于 2008-2-19 15:13 | 显示全部楼层
会要求update LINK-me吗?
3.15B 会要求升级LINK-ME.
3.20会吗?
tsb0574 发表于 2008-2-21 20:56 | 显示全部楼层
等待Crack!!!
hotpower 发表于 2008-2-21 23:28 | 显示全部楼层
5楼帅气~~~
dy008 发表于 2008-2-24 17:07 | 显示全部楼层
支持升级!
同样等..........呵呵!
tsb0574 发表于 2008-2-25 21:49 | 显示全部楼层
看来需要的人还是不少啊……
s99060 发表于 2008-2-26 14:44 | 显示全部楼层
中文帮助还是老的吧..............
