DM6467 GEL文件配置PLL问题
1073|0
 楼主| beandy 发表于 2015-8-27 13:56 | 显示全部楼层 |阅读模式
我最近在调试DM6467,平台CCS6.0+xds200。在配置PPL的时候会出现如下问题:
ARM926: GEL Output:
DaVinci HD1080p ARM Startup Sequence
ARM926: GEL Output: Disable IRQ/FIQ
ARM926: GEL Output: Flush Cache
ARM926: GEL Output: Disable MMU
ARM926: GEL Output: Enable Instruction Cache.
ARM926: GEL Output: Setup PinMux...ARM926: GEL Output: [Done]
ARM926: GEL Output: Setup Power Modules (All on)...ARM926: GEL Output: [Done]
ARM926: GEL Output: Setup PLL0ARM926: GEL Output: (DSP = 594 MHz +ARM926: GEL Output: ARM = 148 MHz +ARM926: GEL Output: Onchip Oscillator)...ARM926: GEL Output: [Done]
ARM926: GEL Output: Setup PLL1ARM926: GEL: Error while executing OnTargetConnect(): Driver did not attempt to read 0x01C40D00         at (*(pll_ctl)&=~(0x0002)) [davincihd1080p_arm.gel:718]         at setup_pll_1(0, 17, 0) [davincihd1080p_arm.gel:840]         at Setup_DDR_396_MHz() [davincihd1080p_arm.gel:44]         at OnTargetConnect() .
在这个例子中PLL0能够配置,但是配置PLL1的时候出现这个问题,好像是配置PLL之后ARM和仿真器断开失去联系了。请问大家怎么解决?谢谢!
