const INTVECT_ELEM AppVectTbl[] = { { .__ptr = __sfe("CSTACK")}, /* 0, SP start value. */ __program_start, /* 1, PC start value. */ App_NMI_ISR, /* 2, NMI */ App_Fault_ISR, /* 3, Hard Fault */ App_Spurious_ISR, /* 4, Memory Management */ App_Spurious_ISR, /* 5, Bus Fault */ App_Spurious_ISR, /* 6, Usage Fault */ 0, /* 7, Reserved */ 0, /* 8, Reserved */ 0, /* 9, Reserved */ 0, /* 10, Reserved */ App_Spurious_ISR, /* 11, SVCall */ App_Spurious_ISR, /* 12, Debug Monitor */ App_Spurious_ISR, /* 13, Reserved */ OSPendSV, /* 14, PendSV Handler */ Tmr_TickISR_Handler, /* 15, uC/OS-II Tick ISR Handler */ App_Spurious_ISR, /* 16, INTISR[ 0], Window Watchdog */ App_Spurious_ISR, /* 17, INTISR[ 1] PVD through EXTI Line Detection */ App_Spurious_ISR, /* 18, INTISR[ 2] Tamper Interrupt */ App_Spurious_ISR, /* 19, INTISR[ 3] RTC Global Interrupt */ App_Spurious_ISR, /* 20, INTISR[ 4] FLASH Global Interrupt */ App_Spurious_ISR, /* 21, INTISR[ 5] RCC Global Interrupt */ App_Spurious_ISR, /* 22, INTISR[ 6] EXTI Line0 Interrupt */ App_Spurious_ISR, /* 23, INTISR[ 7] EXTI Line1 Interrupt */ App_Spurious_ISR, /* 24, INTISR[ 8] EXTI Line2 Interrupt */ App_Spurious_ISR, /* 25, INTISR[ 9] EXTI Line3 Interrupt */ App_Spurious_ISR, /* 26, INTISR[ 10] EXTI Line4 Interrupt */ App_Spurious_ISR, /* 27, INTISR[ 11] DMA Channel1 Global Interrupt */ App_Spurious_ISR, /* 28, INTISR[ 12] DMA Channel2 Global Interrupt */ App_Spurious_ISR, /* 29, INTISR[ 13] DMA Channel3 Global Interrupt */ App_Spurious_ISR, /* 30, INTISR[ 14] DMA Channel4 Global Interrupt */ App_Spurious_ISR, /* 31, INTISR[ 15] DMA Channel5 Global Interrupt */ App_Spurious_ISR, /* 32, INTISR[ 16] DMA Channel6 Global Interrupt */ App_Spurious_ISR, /* 33, INTISR[ 17] DMA Channel7 Global Interrupt */ App_Spurious_ISR, /* 34, INTISR[ 18] ADC Global Interrupt */ App_Spurious_ISR, /* 35, INTISR[ 19] USB High Priority / CAN TX Interrupts */ App_Spurious_ISR, /* 36, INTISR[ 20] USB Low Priority / CAN RX0 Interrupts */ App_Spurious_ISR, /* 37, INTISR[ 21] CAN RX1 Interrupt */ App_Spurious_ISR, /* 38, INTISR[ 22] CAN SCE Interrupt */ App_Spurious_ISR, /* 39, INTISR[ 23] EXTI Line[9:5] Interrupt */ App_Spurious_ISR, /* 40, INTISR[ 24] TIM1 Break Interrupt */ App_Spurious_ISR, /* 41, INTISR[ 25] TIM1 Update Interrupt */ App_Spurious_ISR, /* 42, INTISR[ 26] TIM1 Trigger & Commutation Interrupts */ App_Spurious_ISR, /* 43, INTISR[ 27] TIM2 Global Interrupt */ App_Spurious_ISR, /* 44, INTISR[ 28] TIM3 Global Interrupt */ App_Spurious_ISR, /* 45, INTISR[ 29] TIM4 Global Interrupt */ App_Spurious_ISR, /* 46, INTISR[ 30] I2C1 Event Interrupt */ App_Spurious_ISR, /* 47, INTISR[ 31] I2C1 Error Interrupt */ App_Spurious_ISR, /* 48, INTISR[ 32] I2C2 Event Interrupt */ App_Spurious_ISR, /* 49, INTISR[ 33] I2C2 Error Interrupt */ App_Spurious_ISR, /* 50, INTISR[ 34] SPI1 Global Interrupt */ App_Spurious_ISR, /* 51, INTISR[ 35] SPI2 Global Interrupt */ ProbeRS232_RxTxISRHandler, /* 52, INTISR[ 36] USART1 Global Interrupt */ ProbeRS232_RxTxISRHandler, /* 53, INTISR[ 37] USART2 Global Interrupt */ App_Spurious_ISR, /* 54, INTISR[ 38] USART3 Global Interrupt */ App_Spurious_ISR, /* 55, INTISR[ 39] EXTI Line [15:10] Interrupts */ App_Spurious_ISR, /* 56, INTISR[ 40] RTC Alarm through EXT Line Interrupt */ App_Spurious_ISR, /* 57, INTISR[ 41] USB Wakeup from Suspend through EXTI Int. */ }; 中断跳转到 static void App_Spurious_ISR (void) @ "ICODE" { while (1) { LED_On(1) ; } } 我用的EXTI_Line0中断 中断能产生 但是我怎么判断是EXTI_Line0中断呢 有很多中断都跳到这个里面
