通过DMA采样ADC的11个通道,其一通道不能正确采集,请教?
3320|4
 楼主| zhmili 发表于 2008-6-29 15:10 | 显示全部楼层 |阅读模式
一下为相关的ADC配置代码: vu16 ADC_ConvertedValueROB[12]; void ADC_ConfigruationROB(void) { ADC_InitTypeDef ADC_InitStructure; DMA_InitTypeDef DMA_InitStructure; /* DMA channel1 configuration ----------------------------------------------*/ DMA_DeInit(DMA_Channel1); DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address; DMA_InitStructure.DMA_MemoryBaseAddr = (u32)ADC_ConvertedValueROB; DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; DMA_InitStructure.DMA_BufferSize = 11; DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; DMA_InitStructure.DMA_Priority = DMA_Priority_High; DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; DMA_Init(DMA_Channel1, &DMA_InitStructure); /* Enable DMA channel1 */ DMA_Cmd(DMA_Channel1, ENABLE); /* ADC1 configuration ------------------------------------------------------*/ ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; ADC_InitStructure.ADC_ScanConvMode = ENABLE; ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; ADC_InitStructure.ADC_NbrOfChannel = 11; ADC_Init(ADC1, &ADC_InitStructure); /* ADC1 regular channel10 configuration */ ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_55Cycles5); ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_55Cycles5); ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 3, ADC_SampleTime_55Cycles5); ADC_RegularChannelConfig(ADC1, ADC_Channel_3, 4, ADC_SampleTime_55Cycles5); ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 5, ADC_SampleTime_55Cycles5); ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 6, ADC_SampleTime_55Cycles5); ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 7, ADC_SampleTime_55Cycles5); ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 8, ADC_SampleTime_55Cycles5); ADC_RegularChannelConfig(ADC1, ADC_Channel_13, 9, ADC_SampleTime_55Cycles5); ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 10, ADC_SampleTime_55Cycles5); ADC_RegularChannelConfig(ADC1, ADC_Channel_9, 11, ADC_SampleTime_55Cycles5); /* Enable ADC1 DMA */ ADC_DMACmd(ADC1, ENABLE); /* Enable ADC1 */ ADC_Cmd(ADC1, ENABLE); /* Enable ADC1 reset calibaration register */ ADC_ResetCalibration(ADC1); /* Check the end of ADC1 reset calibration register */ while(ADC_GetResetCalibrationStatus(ADC1)); /* Start ADC1 calibaration */ ADC_StartCalibration(ADC1); /* Check the end of ADC1 calibration */ while(ADC_GetCalibrationStatus(ADC1)); /* Start ADC1 Software Conversion */ ADC_SoftwareStartConvCmd(ADC1, ENABLE); } INT32U ADC_GetConvertValueROB(INT8U ADC_GROUP) { return ADC_ConvertedValueROB[ADC_GROUP-1]; } 试验结果:除了通道十数值错误,其余通道正确现象:1、直接在通道10输入,输出结果不正确 2、通道9输入后,通道10 输出跟着变且与通道9输出结果一样说明:1、硬件线路上通道9和10完全隔开请问发生上述问题的可能原因是什么?
香水城 发表于 2008-6-29 16:04 | 显示全部楼层
你的键盘的回车键是不是坏了?看你的帖好累呀
colaring 发表于 2008-6-29 21:01 | 显示全部楼层
同意
同意香版主,LZ这么帖代码是有点说不过去
samuelyu 发表于 2008-6-30 22:40 | 显示全部楼层
楼主不是 UNIX 下编辑的吧?
 楼主| zhmili 发表于 2008-7-2 15:32 | 显示全部楼层
      /* Enable ADC1 */
