通过DMA采样ADC的11个通道,其一通道不能正确采集,请教?
2571|1
 楼主| zhmili 发表于 2008-7-2 15:36 | 显示全部楼层 |阅读模式
以下是基本的配置代码:
vu16 ADC_ConvertedValueROB[12];
void ADC_ConfigruationROB(void)
      ADC_InitTypeDef ADC_InitStructure;
      DMA_InitTypeDef DMA_InitStructure;
      /* DMA channel1 configuration ----------------------------------------------*/
      DMA_DeInit(DMA_Channel1);
      DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;
      DMA_InitStructure.DMA_MemoryBaseAddr = (u32)ADC_ConvertedValueROB;
      DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
      DMA_InitStructure.DMA_BufferSize = 11;
      DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
      DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
      DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
      DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
      DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
      DMA_InitStructure.DMA_Priority = DMA_Priority_High;
      DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
      DMA_Init(DMA_Channel1, &DMA_InitStructure);
      /* Enable DMA channel1 */
      DMA_Cmd(DMA_Channel1, ENABLE);
      /* ADC1 configuration ------------------------------------------------------*/
      ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
      ADC_InitStructure.ADC_ScanConvMode = ENABLE;
      ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
      ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
      ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
      ADC_InitStructure.ADC_NbrOfChannel = 11;
      ADC_Init(ADC1, &ADC_InitStructure);
      /* ADC1 regular channel10 configuration */
      ADC_RegularChannelConfig(ADC1, ADC_Channel_0,  1, ADC_SampleTime_55Cycles5);
      ADC_RegularChannelConfig(ADC1, ADC_Channel_1,  2, ADC_SampleTime_55Cycles5);
      ADC_RegularChannelConfig(ADC1, ADC_Channel_2,  3, ADC_SampleTime_55Cycles5);
      ADC_RegularChannelConfig(ADC1, ADC_Channel_3,  4, ADC_SampleTime_55Cycles5);
      ADC_RegularChannelConfig(ADC1, ADC_Channel_4,  5, ADC_SampleTime_55Cycles5);
      ADC_RegularChannelConfig(ADC1, ADC_Channel_10,  6, ADC_SampleTime_55Cycles5);
      ADC_RegularChannelConfig(ADC1, ADC_Channel_11,  7, ADC_SampleTime_55Cycles5);
      ADC_RegularChannelConfig(ADC1, ADC_Channel_12,  8, ADC_SampleTime_55Cycles5);
      ADC_RegularChannelConfig(ADC1, ADC_Channel_13,  9, ADC_SampleTime_55Cycles5);
      ADC_RegularChannelConfig(ADC1, ADC_Channel_14,  10, ADC_SampleTime_55Cycles5);
      ADC_RegularChannelConfig(ADC1, ADC_Channel_9,  11, ADC_SampleTime_55Cycles5);
      /* Enable ADC1 DMA */
      ADC_DMACmd(ADC1, ENABLE);
      /* Enable ADC1 */
      ADC_Cmd(ADC1, ENABLE);
      /* Enable ADC1 reset calibaration register */
      ADC_ResetCalibration(ADC1);
      /* Check the end of ADC1 reset calibration register */
      while(ADC_GetResetCalibrationStatus(ADC1));
      /* Start ADC1 calibaration */
      ADC_StartCalibration(ADC1);
      /* Check the end of ADC1 calibration */
      while(ADC_GetCalibrationStatus(ADC1));
      /* Start ADC1 Software Conversion */
      ADC_SoftwareStartConvCmd(ADC1, ENABLE);
INT32U ADC_GetConvertValueROB(INT8U ADC_GROUP)
return ADC_ConvertedValueROB[ADC_GROUP-1];
试验结果:除了通道十数值错误,其余通道正确现象:
1、直接在通道10输入,输出结果不正确
2、通道9输入后,通道10 输出跟着变且与通道9输出结果一样
说明:1、硬件线路上通道9和10完全隔开
请问发生上述问题的可能原因是什么?
香水城 发表于 2008-7-2 16:04 | 显示全部楼层
暂时不知道有什么原因,请尝试改变一下采样的顺序
多试几种组合,看看是否有同样的现象,也许能找出什么规律。
