通过DMA采集11路ADC中出现对应不一致的问题?
3146|3
 楼主| zhmili 发表于 2008-7-6 10:22 | 显示全部楼层 |阅读模式
相关代码如下:
vu16 ADC_ConvertedValueROB[11];
void ADC_ConfigruationROB(void)
      ADC_InitTypeDef ADC_InitStructure;
      DMA_InitTypeDef DMA_InitStructure;
      /* DMA channel1 configuration ----------------------------------------------*/
      DMA_DeInit(DMA_Channel1);
      DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;
      DMA_InitStructure.DMA_MemoryBaseAddr = (u32)ADC_ConvertedValueROB;
      DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
      DMA_InitStructure.DMA_BufferSize = 11;
      DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
      DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
      DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
      DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
      DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
      DMA_InitStructure.DMA_Priority = DMA_Priority_High;
      DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
      DMA_Init(DMA_Channel1, &DMA_InitStructure);
      /* Enable DMA channel1 */
      DMA_Cmd(DMA_Channel1, ENABLE);
      /* ADC1 configuration ------------------------------------------------------*/
      ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
      ADC_InitStructure.ADC_ScanConvMode = ENABLE;
      ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
      ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
      ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
      ADC_InitStructure.ADC_NbrOfChannel = 11;
      ADC_Init(ADC1, &ADC_InitStructure);
      /* ADC1 regular channel10 configuration */
      ADC_RegularChannelConfig(ADC1, ADC_Channel_0,  1, ADC_SampleTime_55Cycles5);
      ADC_RegularChannelConfig(ADC1, ADC_Channel_1,  2, ADC_SampleTime_55Cycles5);
      ADC_RegularChannelConfig(ADC1, ADC_Channel_2,  3, ADC_SampleTime_55Cycles5);
      ADC_RegularChannelConfig(ADC1, ADC_Channel_3,  4, ADC_SampleTime_55Cycles5);
      ADC_RegularChannelConfig(ADC1, ADC_Channel_4,  5, ADC_SampleTime_55Cycles5);
      ADC_RegularChannelConfig(ADC1, ADC_Channel_10,  6, ADC_SampleTime_55Cycles5);
      ADC_RegularChannelConfig(ADC1, ADC_Channel_11,  7, ADC_SampleTime_55Cycles5);
      ADC_RegularChannelConfig(ADC1, ADC_Channel_12,  8, ADC_SampleTime_55Cycles5);
      ADC_RegularChannelConfig(ADC1, ADC_Channel_13,  9, ADC_SampleTime_55Cycles5);
      ADC_RegularChannelConfig(ADC1, ADC_Channel_14,  10, ADC_SampleTime_55Cycles5);
      ADC_RegularChannelConfig(ADC1, ADC_Channel_9,  11, ADC_SampleTime_55Cycles5);
      /* Enable ADC1 DMA */
      ADC_DMACmd(ADC1, ENABLE);
      /* Enable ADC1 */
      ADC_Cmd(ADC1, ENABLE);
      /* Enable ADC1 reset calibaration register */
      ADC_ResetCalibration(ADC1);
      /* Check the end of ADC1 reset calibration register */
      while(ADC_GetResetCalibrationStatus(ADC1));
      /* Start ADC1 calibaration */
      ADC_StartCalibration(ADC1);
      /* Check the end of ADC1 calibration */
      while(ADC_GetCalibrationStatus(ADC1));
      /* Start ADC1 Software Conversion */
      ADC_SoftwareStartConvCmd(ADC1, ENABLE);
INT32U ADC_GetConvertValueROB(INT8U ADC_GROUP)
return ADC_ConvertedValueROB[ADC_GROUP-1];
存在的问题:
在没有操作系统的环境下用此段代码,发觉:
ADC_ConvertedValueROB[0]   对应为 ADC_Channel_0 的值
ADC_ConvertedValueROB[1]   对应为 ADC_Channel_1 的值
ADC_ConvertedValueROB[10]   对应为 ADC_Channel_9 的值
上述代码对应是我们想象中的,试验结果也是对的。
但是当这段代码放入另一个环境(带有操作系统)时发觉:
ADC_ConvertedValueROB[0]   对应为 ADC_Channel_9 的值(为上述代码ADC_RegularChannelConfig()最后一行)
ADC_ConvertedValueROB[1]   对应为 ADC_Channel_0 的值
ADC_ConvertedValueROB[10]   对应为 ADC_Channel_14 的值
规律是都后退了一位,为什么会这样?现在要实时读取11个通道的值,有什麽办法?
说明:
关于初始启动代码
RCC_ConfigurationROB();
  NVIC_ConfigurationROB();
  GPIO_ConfigurationROB();
在两个环境中都是同样的代码
香水城 发表于 2008-7-6 10:56 | 显示全部楼层
记得楼主曾经有一个类似的问题
上次那个问题解决了吗?如果解决的?通过DMA采样ADC的11个通道,其一通道不能正确采集,请教?
这次的问题原则上讲应该是启动DMA、ADC转换或某个指针变换的时机问题,试试把下面这2行放到ADC_ConfigruationROB()的倒数第2个操作:
 楼主| zhmili 发表于 2008-7-6 11:58 | 显示全部楼层
通过DMA采样ADC的11个通道,其一通道不能正确采集,请教?的
该问题为 硬件上 第10通道 CPU输入端虚焊所致
 楼主| zhmili 发表于 2008-7-6 12:17 | 显示全部楼层
通过DMA采集11路ADC中出现对应不一致的问题?问提的解决
这个原因应该是对的
但是安照 香水城 的方法试试把下面这2行放到ADC_ConfigruationROB()的倒数第2个操作:
试验了,结果还是不行。
我试着将上面两行放在最后,也就是     /* Start ADC1 Software Conversion */
之后,结果就可行了!
谢谢香水城!
