AD采集
854|2
 楼主| ddddddd··· 发表于 2015-8-30 21:56 | 显示全部楼层 |阅读模式
AdcRegs.ADCTRL1.bit.ACQ_PS = ADC_SHCLK;
AdcRegs.ADCTRL3.bit.ADCCLKPS = ADC_CKPS;
AdcRegs.ADCTRL1.bit.SEQ_CASC = 1;        // 1  Cascaded mode
AdcRegs.ADCCHSELSEQ1.bit.CONV00 = 0x0;
AdcRegs.ADCTRL1.bit.CONT_RUN = 1;       // Setup continuous run
   AdcRegs.ADCTRL1.bit.SEQ_OVRD = 1;       // Enable Sequencer override feature
AdcRegs.ADCCHSELSEQ1.all = 0x1;  // Initialize all ADC channel selects to A0
   AdcRegs.ADCMAXCONV.bit.MAX_CONV1 = 0x1;  // convert and store in 8 results registers
各位大神,小弟是初学者,这是例程给的AD采集通道是A0,我尝试着改成A1,上面AdcRegs.ADCCHSELSEQ1.bit.CONV001= 0x1;改了又改,发现一直是A0通道采集,我是哪里
理解错了?
还有SampleTable1[array_index++]= ( (AdcRegs.ADCRESULT1)>>4);
AdcRegs.ADCRESULT0改成AdcRegs.ADCRESULT1还是现实A0通道采集,怎么回事?
指点一下,谢谢!
youtome 发表于 2015-8-30 22:39 | 显示全部楼层
哪个芯片的?
 楼主| ddddddd··· 发表于 2015-8-31 18:36 | 显示全部楼层
