TI C6748 BIOSPSP 例子程序I2csample(从BIOS C6SDK 2. 0安装而来)CCS6下编译出错
1242|0
 楼主| 52mcu 发表于 2015-8-31 10:55 | 显示全部楼层 |阅读模式
如下错误提示,是工程设置还是什么问题?
Description        Resource        Path        Location        Type
unresolved symbols remain        i2cSample                         C/C++ Problem
errors encountered during linking; "i2cSample.out" not built        i2cSample                         C/C++ Problem
unresolved symbol main, first referenced in D:\ti\ccsv6\tools\compiler\c6000_7.4.8\lib\rts6740_elf.lib<args_main.obj>        i2cSample                         C/C++ Problem
unresolved symbol user_i2c_init, first referenced in E:\biosWork\i2cdriverEx\i2c\Debug\configPkg\package\cfg\i2cSample_pe674.oe674        i2cSample                         C/C++ Problem
unresolved symbol i2cParams, first referenced in E:\biosWork\i2cdriverEx\i2c\Debug\configPkg\package\cfg\i2cSample_pe674.oe674        i2cSample                         C/C++ Problem
unresolved symbol i2cSampleTask, first referenced in E:\biosWork\i2cdriverEx\i2c\Debug\configPkg\package\cfg\i2cSample_pe674.oe674        i2cSample                         C/C++ Problem
