[i.MX] i.mx287用新生成的updater_ivt.sb进行烧写报错,
2861|4
 楼主| piliyouke 发表于 2015-9-1 13:59 | 显示全部楼层 |阅读模式
i.mx287用新生成的updater_ivt.sb进行烧写报错,用bootlets重新生成updater_ivt.sb。之后,用mfgTool进行烧写之后,串口报错信息如下
mxs-auart.4: ttySP4 at MMIO 0x80072000 (irq = 116) is a mxs-auart.4
Found APPUART 3.1.0
brd: module loaded
loop: module loaded
Loading iSCSI transport class v2.0-870.
i.MX GPMI NFC
NFC: Version 1, 8-chip GPMI and BCH
Boot ROM: Version 1, Single-chip boot area, block mark swapping supported
Scanning for NAND Flash chips...
NAND device: Manufacturer ID: 0xc2, Chip ID: 0xf1 (Macronix NAND 128MiB 3,3V 8-bit)
Scanning device for bad blocks
Bad eraseblock 209 at 0x000001a20000
Boot area protection is enabled.
Creating 2 MTD partitions on "gpmi-nfc-main":
0x000000000000-0x000001400000 : "gpmi-nfc-0-boot"
0x000001400000-0x000008000000 : "gpmi-nfc-general-use"
ARC USBOTG Device Controller driver (1 August 2005)
check_parameters:UTP settings are in place now, overriding defaults
g_file_storage gadget: File-backed Storage Gadget, version: 20 November 2008
g_file_storage gadget: Number of LUNs=1
fsl-usb2-udc: bind to driver g_file_storage
mice: PS/2 mouse device common for all mice
input: mxs-kbd as /devices/platform/mxs-kbd.0/input/input0
input: MXS touchscreen as /devices/virtual/input/input1
mxs-kbd mxs-kbd.0: Invalid button: raw = 2959, normalized = 3025, vddio = 3672
MXS RTC driver v1.0 hardware v2.3.0
mxs-kbd mxs-kbd.0: Invalid button: raw = 2975, normalized = 3022, vddio = 3695
mxs-rtc mxs-rtc.0: rtc core: registered mxs-rtc as rtc0
This is 5V only build.
mxs-mmc: MXS SSP Controller MMC Interface driver
mxs-mmc mxs-mmc.0: mmc0: MXS SSP MMC DMAIRQ 82 ERRIRQ 96
NET: Registered protocol family 17
NET: Registered protocol family 15
mxs-rtc mxs-rtc.0: setting system clock to 1970-01-01 04:02:23 UTC (14543)
Freeing init memory: 128K
init started: BusyBox v1.15.0 ()
starting pid 1691, tty '': '/etc/rc.d/rcS'
Mounting /proc and /sys
mount: mounting tmpfs on /dev failed: Invalid argument
mknod: /dev/console: File exists
Starting the hotplug events dispatcher udevd
Synthesizing initial hotplug events
g_file_storage gadget: high speed config #1
Setting the hostname to freescale
Mounting filesystems
no mount -n -t tmpfs shm /dev/shm
no mount -n -t tmpfs rwfs /mnt/rwfs -o size=512k
mount: mounting usbfs on /proc/bus/usb failed: No such file or directory
no mount tmpfs /tmp -t tmpfs -o size=16m
Starting inetd:
uuc 0.4 [built Feb 21 2014 08:19:00]
UTP: Waiting for device to appear
UTP: file/device node /dev/utp already exists
cpu_id is 28
UTP: received command 'mknod class/mtd,mtd0,/dev/mtd0'
class = 'class/mtd'
item = 'mtd0'
node = /dev/mtd0
type = (null)
UTP: running utp_mk_devnode(class/mtd,mtd0,/dev/mtd0,0x2000)
UTP: file/device node /dev/mtd0 already exists
UTP: sending Success
UTP: received command 'mknod class/mtd,mtd1,/dev/mtd1'
class = 'class/mtd'
item = 'mtd1'
node = /dev/mtd1
type = (null)
UTP: running utp_mk_devnode(class/mtd,mtd1,/dev/mtd1,0x2000)
UTP: file/device node /dev/mtd1 already exists
UTP: received command 'mknod class/misc,ubi_ctrl,/dev/ubi_ctrl'
class = 'class/misc'
item = 'ubi_ctrl'
node = /dev/ubi_ctrl
type = (null)
UTP: running utp_mk_devnode(class/misc,ubi_ctrl,/dev/ubi_ctrl,0x2000)
UTP: file/device node /dev/ubi_ctrl already exists
UTP: received command '$ flash_eraseall /dev/mtd0'
UTP: sending Busy
UTP: executing "flash_eraseall /dev/mtd0"
Erasing 128 Kibyte @ 1400000 -- 100 % complete.
UTP: received command 'send'
UTP: received command '$ kobs-ng init -v $FILE'
UTP: sending Busy
UTP: executing "kobs-ng init -v $FILE"
Couldn't discover Boot ROM version
UTP: sending Non-success
utp_poll: exit with status 256
提示:Couldn't discover Boot ROM version,貌似是这个version不对
FSL_TICS_Rita 发表于 2015-9-1 14:50 | 显示全部楼层
楼主你好,请问你这里是要写到SD卡上吗?写到SD上的话,建议你最好使用读卡器往里烧写。
 楼主| piliyouke 发表于 2015-9-5 10:59 来自手机 | 显示全部楼层
楼主你好,请问你这里是要写到SD卡上吗?写到SD上的话,建议你最好使用读卡器往里烧写。 ...
我是要烧写到nand上
芙蓉洞 发表于 2015-9-5 21:01 | 显示全部楼层
是研究的Linux吧,用的什么方法烧写的呢
 楼主| piliyouke 发表于 2015-9-8 09:05 | 显示全部楼层
我是要烧写到nand上
还是没有人回复啊
