[i.MX] IMX6Q内核关闭
888|3
 楼主| 进击的ic 发表于 2015-9-1 15:27 | 显示全部楼层 |阅读模式
公司要做一款手持,现在处于硬件初步研发阶段,买了两块IMX6Q的开发板做功耗测试,四核的CPU功耗太大,想关掉两个测测看,怎么关闭内核呢?求大神支招,帮帮隔行的硬件攻城狮
FSL_TICS_Rita 发表于 2015-9-1 16:11 | 显示全部楼层
When you boot up kernel, just add maxcpus=2 in command line, kernel will only boot two CPUs.
Also, you can cut the VDDARM23_IN, and config the menu config to support two cores and rebuild kernel.
These cores are identical, I think for your experiment, you can just add "maxcpus=2" in command line for testing. And for you product, you can get our Dual core version i.MX6D.
Also, you can "echo 0 > /sys/device/system/cpu/cpuX/online" (X is 2 or 3) to remove one core. echo "1" is to add them back.
奥德赛 发表于 2015-9-1 20:52 | 显示全部楼层
关闭内核是不是别的功能也跑步起来了?
mini1986 发表于 2015-9-2 09:20 | 显示全部楼层
imx6做手持,你们想多了......以imx6的功耗来讲根本不适合手持设备......换其他方案吧......
