Cy68013A程序帮忙指点下!
1130|0
 楼主| mcuatmel 发表于 2015-9-2 12:56 | 显示全部楼层 |阅读模式
Slave FIFO程序,初始化部分:
void TD_Init( void )
{ // Called once at startup
  CPUCS = 0x12; // CLKSPD[1:0]=10, for 48MHz operation, output CLKOUT
  PINFLAGSAB = 0x08;                        // FLAGA - EP2EF    ,怎么确定是EP2?
  SYNCDELAY;
  PINFLAGSCD = 0xE0;                        // FLAGD - EP6FF    ,怎么确定是EP6?
  SYNCDELAY;
  PORTACFG |= 0x80;
  SYNCDELAY;
  IFCONFIG = 0xE3; //Internal clock, 48 MHz, Slave FIFO interface
  SYNCDELAY;
另一个程序中却是这样儿写的:
        SYNCDELAY;
        PINFLAGSAB = 0xE6;          // FLAGA - fixed EP6PF, FLAGB - fixed EP6FF
        SYNCDELAY;
        PINFLAGSCD = 0xf8;          // FLAGC - fixed EP2EF, FLAGD - reserved
        SYNCDELAY;
        PORTACFG |=  0x00;  //0x40;             // SLCS, set alt. func. of PA7 pin
        SYNCDELAY;
        FIFOPINPOLAR = 0x00;          // all signals active low,
        SYNCDELAY;
同样是PINFLAGSAB,怎么就是对6操作呢?
