[AVR单片机] ATmega32A串口通信奇怪问题
970|0
 楼主| cloudou14 发表于 2015-9-5 11:57 | 显示全部楼层 |阅读模式
测试ATmega32A串口通信,使用内部1M振荡,
熔丝设置通信发送ASCII码0~2,返回十六进制均为两个字节,3e 00, 4c 00, 66 00,如此简单的东西都无**常工作,令人费解。请大家帮帮忙,谢谢啦!
//ICC-AVR application builder : 2015-09-05 10:23:35
// Target : M32
// Crystal: 1.0000Mhz
#include <iom32v.h>
#include <macros.h>
void USART_Transmit( unsigned char data );
void port_init(void)
PORTA = 0x00;
DDRA  = 0x00;
PORTB = 0x00;
DDRB  = 0x00;
PORTC = 0x00;
DDRC  = 0x00;
PORTD = 0x00;
DDRD  = 0x00;
//UART0 initialize
// desired baud rate: 9600
// actual: baud rate:9615 (0.2%)
void uart0_init(void)
UCSRB = 0x00; //disable while setting baud rate
UCSRA = 0x02;
UCSRC = BIT(URSEL) | 0x06;
UBRRL = 0x0C; //set baud rate lo
UBRRH = 0x00; //set baud rate hi
UCSRB = 0x98;
#pragma interrupt_handler uart0_rx_isr:iv_USART0_RXC
void uart0_rx_isr(void)
//uart has received a character in UDR
unsigned char i=0;
i=UDR;
USART_Transmit(i);
//call this routine to initialize all peripherals
void init_devices(void)
//stop errant interrupts until set up
CLI(); //disable all interrupts
port_init();
uart0_init();
MCUCR = 0x00;
GICR  = 0x00;
TIMSK = 0x00; //timer interrupt sources
SEI(); //re-enable interrupts
//all peripherals are now initialized
/* 等待发送缓冲器为空 */
while ( !( UCSRA & (1<<UDRE)) )
/* 将数据放入缓冲器,发送数据 */
UDR = data;
void main(void)
        init_devices();
        while(1)
