请大家给我指点一下
2742|0
 楼主| jackbao 发表于 2008-4-15 19:23 | 显示全部楼层 |阅读模式
                                         INCLUDE FILES
#include <includes.h>
*                                            LOCAL DEFINES
#define  APP_LINE_0                0
#define  APP_LINE_1               24
#define  APP_LINE_2               48
#define  APP_LINE_3               72
#define  APP_LINE_4               96
#define  APP_LINE_5              120
#define  APP_LINE_6              144
#define  APP_LINE_7              168
#define  APP_LINE_8              192
#define  APP_LINE_9              216
#define  COLOR_WHITE          0xFFFF
#define  COLOR_BLACK          0x0000
#define  COLOR_BLUE           0x001F
#define  COLOR_BLUE2          0x051F
#define  COLOR_RED            0xF800
#define  COLOR_MAGENTA        0xF81F
#define  COLOR_GREEN          0x07E0
#define  COLOR_CYAN           0x7FFF
#define  COLOR_YELLOW         0xFFE0
*                                       LOCAL GLOBAL VARIABLES
        /* ----------------- APPLICATION GLOBALS ------------------ */
static  OS_STK          AppTaskStartStk[APP_TASK_START_STK_SIZE];
static  OS_STK          AppTaskUserIFStk[APP_TASK_USER_IF_STK_SIZE];
static  OS_STK          AppTaskKbdStk[APP_TASK_KBD_STK_SIZE];
static  OS_EVENT       *AppUserIFMbox;
static  CPU_CHAR        AppLCDLine0[21];
static  CPU_CHAR        AppLCDLine1[21];
static  CPU_CHAR        AppLCDLine2[21];
static  CPU_CHAR        AppLCDLine3[21];
static  CPU_CHAR        AppLCDLine4[21];
static  CPU_CHAR        AppLCDLine5[21];
static  CPU_CHAR        AppLCDLine6[21];
static  CPU_CHAR        AppLCDLine7[21];
static  CPU_CHAR        AppLCDLine8[21];
static  CPU_CHAR        AppLCDLine9[21];
        /* -------------- uC/PROBE RELATED GLOBALS ---------------- */
#if (uC_PROBE_OS_PLUGIN > 0)
volatile  CPU_INT32U    Probe_Counts;
volatile  CPU_BOOLEAN   Probe_B1;
volatile  CPU_BOOLEAN   Probe_JoyLeft;
volatile  CPU_BOOLEAN   Probe_JoyRight;
volatile  CPU_BOOLEAN   Probe_JoyUp;
volatile  CPU_BOOLEAN   Probe_JoyDown;
volatile  CPU_BOOLEAN   Probe_JoyCenter;
volatile  CPU_INT16U    Probe_ADC;
#endif
#if (uC_PROBE_COM_MODULE   > 0) &&
    (PROBE_COM_SUPPORT_STR > 0)
static  OS_STK          AppTaskProbeStrStk[APP_TASK_PROBE_STR_STK_SIZE];
#endif
#if (uC_PROBE_OS_PLUGIN    > 0) &&
    (PROBE_COM_STAT_EN     > 0)
static  CPU_FP32        Probe_RS232RxSpd;
static  CPU_FP32        Probe_RS232TxSpd;
static  CPU_FP32        Probe_ComRxPktSpd;
static  CPU_FP32        Probe_ComTxPktSpd;
static  CPU_FP32        Probe_ComTxSymSpd;
static  CPU_FP32        Probe_ComTxSymByteSpd;
static  CPU_INT32U      Probe_RS232RxLast;
static  CPU_INT32U      Probe_RS232TxLast;
static  CPU_INT32U      Probe_ComRxPktLast;
static  CPU_INT32U      Probe_ComTxPktLast;
static  CPU_INT32U      Probe_ComTxSymLast;
static  CPU_INT32U      Probe_ComTxSymByteLast;
static  CPU_INT32U      Probe_ComCtrLast;
#endif
