STR912FAW44X6 SSP 出现问题
4747|1
 楼主| boclandc 发表于 2008-4-17 09:11 | 显示全部楼层 |阅读模式
ST, pi, IO, gp, GPIO
  GPIO_InitTypeDef  GPIO_InitStructure;
  SSP_InitTypeDef   SSP_InitStructure;
  /* Enable the __SSP0 Clock */
  SCU_APBPeriphClockConfig(__SSP0 ,ENABLE);
  /* Enable the __SSP1 Clock */
  SCU_APBPeriphClockConfig(__SSP1 ,ENABLE);
  /* Enable the __GPIO2 for SSP0 Clock */
  SCU_APBPeriphClockConfig(__GPIO1 ,ENABLE);
  /* Enable the __GPIO3 for SSP1 Clock */
  SCU_APBPeriphClockConfig(__GPIO5 ,ENABLE);
  /* SSP0 and SSP1 pins Config */
//P5.4 P5.5 P5.6 P5.7
  GPIO_DeInit(GPIO5);
  /*Gonfigure SSP0_CLK, SSP0_MOSI, SSP0_nSS pins */
  GPIO_InitStructure.GPIO_Direction = GPIO_PinOutput;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Type = GPIO_Type_PushPull ;
  GPIO_InitStructure.GPIO_Alternate = GPIO_OutputAlt2  ;
  GPIO_Init (GPIO5, &GPIO_InitStructure);
   /*Gonfigure SSP0_MISO pin GPIO5.6*/
  GPIO_InitStructure.GPIO_Direction = GPIO_PinInput;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
  GPIO_InitStructure.GPIO_IPInputConnected = GPIO_IPInputConnected_Enable;
  GPIO_InitStructure.GPIO_Alternate = GPIO_InputAlt1  ;
//P1.0 P1.1 P1.2 P1.3
  GPIO_DeInit(GPIO1);
   /*Gonfigure SSP0_MISO pin GPIO1.2*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_Init (GPIO1, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_3;
  GPIO_InitStructure.GPIO_Alternate = GPIO_OutputAlt3  ;
   /* SSP0 configuration */
  SSP_DeInit(SSP0);
  SSP_InitStructure.SSP_FrameFormat = SSP_FrameFormat_Motorola;
  SSP_InitStructure.SSP_Mode = SSP_Mode_Master;
  SSP_InitStructure.SSP_CPOL = SSP_CPOL_Low;
  SSP_InitStructure.SSP_CPHA = SSP_CPHA_2Edge;
  SSP_InitStructure.SSP_DataSize = SSP_DataSize_16b;
  SSP_InitStructure.SSP_ClockRate = 5;
  SSP_InitStructure.SSP_ClockPrescaler = 2;
  SSP_Init(SSP0, &SSP_InitStructure);
  SSP_DeInit(SSP1);
  SSP_Init(SSP1, &SSP_InitStructure);
  /* SSP0 enable */
  SSP_Cmd(SSP0, ENABLE);
  /* SSP1 enable */
  SSP_Cmd(SSP1, ENABLE);
当执行至
SSP_InitStructure.SSP_CPHA = SSP_CPHA_2Edge; 后CPU死机.
连JTAG都不认了!需要重新上电后才能再次使用.
使用的库是最新从官方网站下载的.V2.0
右下角的版本号是:G
不知是不是芯片上的问题.
STF 发表于 2008-4-17 18:08 | 显示全部楼层
STR912
你好,
我做过一些测试,我用你的程序的时候没有碰到过这个问题
请问,你用哪一个开发工具?
请问,每一次芯片死机是在同样的地方?
请问,如果你中间加程序的话还是在原来那个地方?
Regards,
