usb的问题
2224|1
 楼主| dkill 发表于 2008-6-25 15:55 | 显示全部楼层 |阅读模式
USB, TI, ST, ic, ck
DEVICE_PROP Device_Property =
    Joystick_init,
    Joystick_Reset,
    Joystick_Status_In,
    Joystick_Status_Out,
    Joystick_Data_Setup,
    Joystick_NoData_Setup,
    Joystick_Get_Interface_Setting,
    Joystick_GetDeviceDescriptor,
    Joystick_GetConfigDescriptor,
    Joystick_GetStringDescriptor,
    0,
    0x40 /*MAX PACKET SIZE*/
这个里面调用了很多函数
比如Joystick_Data_Setup调用
 Joystick_Data_Setup(u8 RequestNo)
  u8 *(*CopyRoutine)(u16);
  CopyRoutine = NULL;
  if ((RequestNo == GET_DESCRIPTOR)
      && (Type_Recipient == (STANDARD_REQUEST | INTERFACE_RECIPIENT))
      && (pInformation->USBwIndex0 == 0))
    if (pInformation->USBwValue1 == REPORT_DESCRIPTOR)
      CopyRoutine = Joystick_GetReportDescriptor;
    else if (pInformation->USBwValue1 == HID_DESCRIPTOR_TYPE)
      CopyRoutine = Joystick_GetHIDDescriptor;
  } /* End of GET_DESCRIPTOR */
  /*** GET_PROTOCOL ***/
  else if ((Type_Recipient == (CLASS_REQUEST | INTERFACE_RECIPIENT))
           && RequestNo == GET_PROTOCOL)
    CopyRoutine = Joystick_GetProtocolValue;
  if (CopyRoutine == NULL)
    return USB_UNSUPPORT;
  pInformation->Ctrl_Info.CopyData = CopyRoutine;
  pInformation->Ctrl_Info.Usb_wOffset = 0;
  (*CopyRoutine)(0);
  return USB_SUCCESS;
但是我怎么也不明白 调用的这个函数的参数在哪里给过值
 Joystick_Data_Setup(u8 RequestNo)里面的RequestNo
郁闷
香水城 发表于 2008-6-25 16:51 | 显示全部楼层
这个函数是由USB库调用的,所以参数是从库中给出的
