可是我的LCD就是驱动不起来 我用的vet6(100pin)驱动8080lcd,信号都对,就是时序的问题; 有劳大家帮我看看,万分感谢!
下面是FSMC配置函数; #define LCD_BASE ((u32)(0x60000000 | 0x00000000)) ///*!!!!!!!!!!!!!!!!!!!!!!!!!!!!! #define LCD ((LCD_TypeDef *) LCD_BASE)
#define LCD1_BASE ((u32)(0x60000000 | 0x00010000)) ///*!!!!!!!!!!!!!!!!!!!!!!!!!!!!! #define LCD1 ((LCD1_TypeDef *) LCD1_BASE)
void LCD_FSMCConfig(void) { /* NOE and NWE configuration */ //GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 |GPIO_Pin_5; //GPIO_Init(GPIOD, &GPIO_InitStructure); /* NE3 configuration */ // GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; // GPIO_Init(GPIOG, &GPIO_InitStructure); FSMC_NORSRAMInitTypeDef FSMC_NORSRAMInitStructure; FSMC_NORSRAMTimingInitTypeDef p;
/*-- FSMC Configuration ------------------------------------------------------*/ /* FSMC_Bank1_NORSRAM4 timing configuration */ p.FSMC_AddressSetupTime = 1; p.FSMC_AddressHoldTime = 0; p.FSMC_DataSetupTime =4; p.FSMC_BusTurnAroundDuration = 0; p.FSMC_CLKDivision = 0; p.FSMC_DataLatency = 0; p.FSMC_AccessMode = FSMC_AccessMode_A; //p.FSMC_AccessMode = FSMC_AccessMode_B; //p.FSMC_AccessMode = FSMC_AccessMode_A; /* FSMC_Bank1_NORSRAM4 configured as follows: - Data/Address MUX = Disable - Memory Type = SRAM - Data Width = 16bit - Write Operation = Enable - Extended Mode = Disable - Asynchronous Wait = Disable */ //FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM4; FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM1; FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable; //FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Enable; FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_SRAM; //FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_NOR; //FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b; FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_8b; FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable; FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low; FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable; FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState; FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable; FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable; FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable; FSMC_NORSRAMInitStructure.FSMC_AsyncWait = FSMC_AsyncWait_Disable; FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable; FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &p; FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &p;
FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);
/* Enable FSMC_Bank1_NORSRAM4 */ //FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM4, ENABLE); FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM1, ENABLE); }
/******************* (C) COPYRIGHT 2008 STMicroelectronics *****END OF FILE****/
void LCD_CtrlLinesConfig(void) { GPIO_InitTypeDef GPIO_InitStructure;
/* Enable FSMC, GPIOD, GPIOE, GPIOF, GPIOG and AFIO clocks */ RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC, ENABLE);
RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE | RCC_APB2Periph_AFIO, ENABLE);
/* Set PD.00(D2), PD.01(D3), PD.04(NOE), PD.05(NWE), PD.08(D13), PD.09(D14), PD.10(D15), PD.14(D0), PD.15(D1) as alternate function push pull */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_14 | GPIO_Pin_15; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOD, &GPIO_InitStructure);
/* Set PE.07(D4), PE.08(D5), PE.09(D6), PE.10(D7), PE.11(D8), PE.12(D9), PE.13(D10), PE.14(D11), PE.15(D12) as alternate function push pull */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10; GPIO_Init(GPIOE, &GPIO_InitStructure);
/* Set PF.00(A16 (RS)) as alternate function push pull */ // GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; //GPIO_Init(GPIOF, &GPIO_InitStructure); //GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; //GPIO_Init(GPIOE, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11; GPIO_Init(GPIOD, &GPIO_InitStructure);
/* Set PG.12(NE1 (LCD/CS)) as alternate function push pull - CE3(LCD /CS) */ //GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12; //GPIO_Init(GPIOG, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7; GPIO_Init(GPIOD, &GPIO_InitStructure); }
