STM32如何实现串口 7位数据收发?
7566|2
 楼主| midway 发表于 2008-8-21 09:39 | 显示全部楼层 |阅读模式
STM32手册上写的是串口只有8位和9位数据传递方式。怎么解决?
香水城 发表于 2008-8-21 10:59 | 显示全部楼层
可以用带奇偶校验的8位数据格式
shenlanstm 发表于 2008-8-26 17:22 | 显示全部楼层
STM32中断问题 串口中断
开了中断可是不知道怎么回事,老进入ISR,我的设置过程如下,请高手帮忙看下问题出在哪里
当执行到下面时,老是进入USART1_IRQHandler();
    USART_ITConfig(USART1,USART_IT_TXE,ENABLE);
void NVIC_Config(void)
      NVIC_InitTypeDef NVIC_USART1_S;
     NVIC_DeInit();
     NVIC_SCBDeInit();
  //  NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
//    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
     NVIC_ClearIRQChannelPendingBit(USART1_IRQChannel);
      NVIC_USART1_S.NVIC_IRQChannel= USART1_IRQChannel;
     NVIC_USART1_S.NVIC_IRQChannelPreemptionPriority    =3;
     NVIC_USART1_S.NVIC_IRQChannelSubPriority=5;
     NVIC_USART1_S.NVIC_IRQChannelCmd=ENABLE;
     NVIC_Init(&NVIC_USART1_S);
void SetupUART (void)  {
  GPIO_InitTypeDef  GPIO_InitStructure;
  USART_InitTypeDef USART_InitStructure;
  /* Enable GPIOA clock                                                       */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
  /* Configure USART1 Rx (PA10) as input floating                             */
  GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_10;
  GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_IN_FLOATING;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /* Configure USART1 Tx (PA9) as alternate function push-pull                */
  GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_9;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AF_PP;
  /* USART1 configured as follow:
        - BaudRate = 115200 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
        - USART Clock disabled
        - USART CPOL: Clock is active low
        - USART CPHA: Data is captured on the middle
        - USART LastBit: The clock pulse of the last data bit is not output to
                         the SCLK pin
  USART_InitStructure.USART_BaudRate            = 9600;
  USART_InitStructure.USART_WordLength          = USART_WordLength_8b;
  USART_InitStructure.USART_StopBits            = USART_StopBits_1;
  USART_InitStructure.USART_Parity              = USART_Parity_No ;
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  USART_InitStructure.USART_Mode                = USART_Mode_Rx | USART_Mode_Tx;
  USART_InitStructure.USART_Clock               = USART_Clock_Disable;
  USART_InitStructure.USART_CPOL                = USART_CPOL_Low;
  USART_InitStructure.USART_CPHA                = USART_CPHA_2Edge;
  USART_InitStructure.USART_LastBit             = USART_LastBit_Disable;
  USART_Init(USART1, &USART_InitStructure);
    //CONFIG  USART INTERRPUT  //add 2008 8-11        zsf
      USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);
 //  USART1->    CR1|=0x00a0;
  USART_Cmd(USART1, ENABLE);            /* Enable USART1                      */
void USART1_IRQHandler(void)
 // GPIOB->ODR = (GPIOB->ODR & 0xFFFF00FF) | (LED1 << 8);
       if(USART_GetITStatus(USART1, USART_FLAG_RXNE)==SET)
         USART_ITConfig(USART3, USART_IT_RXNE, DISABLE);
        GPIOB->ODR = (GPIOB->ODR & 0xFFFF00FF) | (2 << 8);
         Read_Byte=USART_ReceiveData(USART1);
    if(USART_GetITStatus(USART1, USART_IT_TXE)==SET)
    //    USART_ClearITPendingBit(USART1,USART_IT_TXE);
        GPIOB->ODR = (GPIOB->ODR & 0xFFFF00FF) | (1 << 8);
    //    USART1->DR=0x55;
        // USART_SendData(USART1,100);
      /* If a Frame error is signaled by the card */
  if(USART_GetITStatus(USART1, USART_IT_FE) != RESET)
    /* Resend the byte that failed to be received (by the Smartcard) correctly */
   // SC_ParityErrorHandler();
  /* If the USART3 detects a parity error */
  if(USART_GetITStatus(USART1, USART_IT_PE) != RESET)
    /* Enable USART3 RXNE Interrupt (until receiving the corrupted byte) */
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
    /* Flush the USART3 DR register */
  if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
    /* Disable USART3 RXNE Interrupt */
    USART_ITConfig(USART1, USART_IT_RXNE, DISABLE);
  /* If a Overrun error is signaled by the card */
  if(USART_GetITStatus(USART1, USART_IT_ORE) != RESET)
  /* If a Noise error is signaled by the card */
  if(USART_GetITStatus(USART1, USART_IT_NE) != RESET)
