[AVR单片机] x5045的EEPROM写不进去,但是能读出来??
1476|1
 楼主| qazplm3218 发表于 2015-9-10 21:01 | 显示全部楼层 |阅读模式
void wren_cmd(void)
    x5045_SCK_Clr;
    delay_us(5);
    x5045_CS_Clr;
    write_x5045(0x06);
    x5045_SCK_Clr;
    delay_us(5);
    x5045_CS_Set;
void wrdi_cmd(void)
    x5045_SCK_Clr;
    delay_us(5);
    x5045_CS_Clr;
    write_x5045(0x04);
    x5045_SCK_Clr;
    delay_us(5);
    x5045_CS_Set;
void write_x5045(unsigned char data)
     unsigned char x,y;
     x5045_SCK_Clr;
     for(x=0;x<8;x++)
         if((data&0x80)==0x80)
             x5045_SI_Set;
         else
             x5045_SI_Clr;
         delay_us(5);
         x5045_SCK_Clr;
         delay_us(5);
         x5045_SCK_Set;
         delay_us(5);
         data<<=1;
     x5045_SI_Clr;
void x5045_write_data(unsigned char data,unsigned char add)    //给x5045指定地址写入数据
    x5045_SCK_Clr;
    delay_us(5);
    x5045_CS_Clr;
    wren_cmd();
    x5045_CS_Set;
    delay_us(5);
    x5045_CS_Clr;
    write_x5045(0x02);
    write_x5045(add);
    write_x5045(data);
    x5045_CS_Set;
    delay_us(5);
    x5045_SCK_Clr;
    wrdi_cmd();
请各位帮帮忙,看看是有问题?谢谢!!
694844985 发表于 2015-9-11 09:02 | 显示全部楼层
你怎么确定能写进去,首先确定硬件是不是有问题,然后认真阅读数据手册,看看时序是不是有问题。
