什么是DSP内存双映射
1476|2
 楼主| wangjiahao88 发表于 2015-9-10 21:03 | 显示全部楼层 |阅读模式
TM320F28027的内存图,此DSP是片上32K FLASH, 和片上6K RAM。
现在有个问题搞不明白,如图上的红框框,有两个L0 SARAM (4K x 16) 的 Dual Mapped空间,字面意思是双映射空间,但这个具体是什么意思,怎么理解呢?
这两个是随便用的还是怎么?实在是不明白,求帮忙解答!!!
東南博士 发表于 2015-9-10 21:04 | 显示全部楼层
L0与L1是镜像关系,具体用哪个要看CMD文件下面是CCS自带CMD的部分
从中看到它用了0x00 8000 – 0x00 8FFF的空间,那么0x3F 8000 – 0x3F 8FFF这个还能不能用?当然可以,但容量还是4Kx16,因为这两部分地址空间是重叠的,所以分配内存空间时要小心,不要重了。
MEMORY
PAGE 0:    /* Program Memory */
           /* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE1 for data allocation */
   PRAML0      : origin = 0x008000, length = 0x000800     /* on-chip RAM block L0 */
   OTP         : origin = 0x3D7800, length = 0x000400     /* on-chip OTP */
   FLASHD      : origin = 0x3F0000, length = 0x002000     /* on-chip FLASH */
   FLASHC      : origin = 0x3F2000, length = 0x002000     /* on-chip FLASH */
   FLASHA      : origin = 0x3F6000, length = 0x001F80     /* on-chip FLASH */
   CSM_RSVD    : origin = 0x3F7F80, length = 0x000076     /* Part of FLASHA.  Program with all 0x0000 when CSM is in use. */
   BEGIN       : origin = 0x3F7FF6, length = 0x000002     /* Part of FLASHA.  Used for "boot to Flash" bootloader mode. */
   CSM_PWL_P0  : origin = 0x3F7FF8, length = 0x000008     /* Part of FLASHA.  CSM password locations in FLASHA */
   IQTABLES    : origin = 0x3FE000, length = 0x000B50     /* IQ Math Tables in Boot ROM */
   IQTABLES2   : origin = 0x3FEB50, length = 0x00008C     /* IQ Math Tables in Boot ROM */
   IQTABLES3   : origin = 0x3FEBDC, length = 0x0000AA          /* IQ Math Tables in Boot ROM */
   ROM         : origin = 0x3FF27C, length = 0x000D44     /* Boot ROM */
   RESET       : origin = 0x3FFFC0, length = 0x000002     /* part of boot ROM  */
   VECTORS     : origin = 0x3FFFC2, length = 0x00003E     /* part of boot ROM  */
PAGE 1 :   /* Data Memory */
           /* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE0 for program allocation */
           /* Registers remain on PAGE1                                                  */
   BOOT_RSVD   : origin = 0x000000, length = 0x000050     /* Part of M0, BOOT rom will use this for stack */
   RAMM0       : origin = 0x000050, length = 0x0003B0     /* on-chip RAM block M0 */
   RAMM1       : origin = 0x000400, length = 0x000400     /* on-chip RAM block M1 */
   DRAML0      : origin = 0x008800, length = 0x000800     /* on-chip RAM block L0 */
   FLASHB      : origin = 0x3F4000, length = 0x002000     /* on-chip FLASH */
shenmu2012 发表于 2015-9-12 14:41 | 显示全部楼层
这个不怎明白的,学习了。
