[应用相关] 使用STM32的USART3通讯老死机
4041|0
 楼主| leewen 发表于 2009-2-28 19:27 | 显示全部楼层 |阅读模式
在用USART3通讯时,不断发送数据时就死机了。当停止IAR编译器,出现"CPU not halted",哪位高手遇到这种情况,可能哪些原因引起的,
初始化:
 USART_InitStructure.USART_BaudRate = 9600;
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  USART_InitStructure.USART_StopBits = USART_StopBits_1;
  USART_InitStructure.USART_Parity = USART_Parity_No;
  USART_InitStructure.USART_HardwareFlowControl =    USART_HardwareFlowControl_None;
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  USART_InitStructure.USART_Clock = USART_Clock_Disable;
  USART_InitStructure.USART_CPOL = USART_CPOL_Low;
  USART_InitStructure.USART_CPHA = USART_CPHA_2Edge;
  USART_InitStructure.USART_LastBit = USART_LastBit_Disable;
  USART_Init(USART3, &USART_InitStructure);
USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);
 USART_ITConfig(USART3, USART_IT_TXE, ENABLE);
  USART_Cmd(USART1, ENABLE);
中断函数:
void USART3_IRQHandler(void)
BYTE bTmp;
  if(USART_GetITStatus(USART3, USART_IT_RXNE) != RESET)
    /* Clear the USART3 Receive interrupt */
     USART_ClearITPendingBit(USART3, USART_IT_RXNE);
    bTmp = (USART_ReceiveData(USART3) & 0x7F);;
  if(USART_GetITStatus(USART3, USART_IT_TXE) != RESET)
    /* Clear the USART3 transmit interrupt */
    USART_ClearITPendingBit(USART3, USART_IT_TXE);
    if(fgUartTxBufOut(&bTmp) == TRUE )
          USART_SendData(USART3, bTmp);
    else
         USART_ITConfig(USART3, USART_IT_TXE, DISABLE);
刚开始通讯都正常,一直有数据通讯时,一会儿就死机了。
