有没有耐压700v,0.2-0.5A的开关三级管
3176|11
 楼主| xuhui_tjut 发表于 2007-8-2 11:03 | 显示全部楼层 |阅读模式
有没有耐压700v,0.2-0.5A的开关三级管,<br />不知道有没有这种高耐压,低电流的开关三极管,找半天没找着
zhuchenjie 发表于 2007-8-2 11:04 | 显示全部楼层
我是新手
我是新手,我是来学习的,相信前辈会给你提供帮助的.
lyjian 发表于 2007-8-2 12:16 | 显示全部楼层
大把
上ON和ST等公司网站自己看
tyw 发表于 2007-8-2 16:52 | 显示全部楼层
参考一下
<table class=ubb cellspacing=0><TR><td class=ubb>1&nbsp;&nbsp;&nbsp;</td><td class=ubb>型号&nbsp;&nbsp;&nbsp;&nbsp;</td><td class=ubb>型号1</td><td class=ubb>型号2&nbsp;</td><td class=ubb>电压</td><td class=ubb>电流&nbsp;</td><td class=ubb>功率</td><td class=ubb>频率</td><td class=ubb>极性&nbsp;&nbsp;</td><td class=ubb>材料&nbsp;&nbsp;</td><td class=ubb>沟道电阻</td><td class=ubb>&nbsp;&nbsp;1</td><td class=ubb></td></TR></table><table class=ubb cellspacing=0><TR><td class=ubb>2749</td><td class=ubb>BS170</td><td class=ubb>BS170</td><td class=ubb>BS170</td><td class=ubb>1000</td><td class=ubb>0.3</td><td class=ubb>0.8</td><td class=ubb>-</td><td class=ubb>N-FET</td><td class=ubb>N-FET</td><td class=ubb>5&nbsp;Ohm</td><td class=ubb>2749</td></TR><TR><td class=ubb>2750</td><td class=ubb>THD200FI</td><td class=ubb>THD</td><td class=ubb>200FI</td><td class=ubb>1000</td><td class=ubb>10</td><td class=ubb>60</td><td class=ubb>-</td><td class=ubb>NPN</td><td class=ubb>SI</td><td class=ubb>-</td><td class=ubb>2750</td></TR><TR><td class=ubb>2751</td><td class=ubb>BS208</td><td class=ubb>BS208</td><td class=ubb>BS208</td><td class=ubb>1000</td><td class=ubb>0.2</td><td class=ubb>0.8</td><td class=ubb>-</td><td class=ubb>P-FET</td><td class=ubb>P-FET</td><td class=ubb>-</td><td class=ubb>2751</td></TR><TR><td class=ubb>2752</td><td class=ubb>MJE210</td><td class=ubb>MJ</td><td class=ubb>210</td><td class=ubb>1000</td><td class=ubb>5</td><td class=ubb>15</td><td class=ubb>65</td><td class=ubb>PNP</td><td class=ubb>SI</td><td class=ubb>-</td><td class=ubb>2752</td></TR><TR><td class=ubb>2753</td><td class=ubb>ZTX213</td><td class=ubb>ZTX</td><td class=ubb>213</td><td class=ubb>1000</td><td class=ubb>0.2</td><td class=ubb>0.3</td><td class=ubb>350</td><td class=ubb>PNP</td><td class=ubb>SI</td><td class=ubb>-</td><td class=ubb>2753</td></TR><TR><td class=ubb>2754</td><td class=ubb>IRF230</td><td class=ubb>IRF</td><td class=ubb>230</td><td class=ubb>1000</td><td class=ubb>9</td><td class=ubb>75</td><td class=ubb>-</td><td class=ubb>N-FET</td><td class=ubb>N-FET</td><td class=ubb>0,4&nbsp;Ohm</td><td class=ubb>2754</td></TR><TR><td class=ubb>2755</td><td class=ubb>MRF237</td><td class=ubb>MRF</td><td class=ubb>237</td><td class=ubb>1000</td><td class=ubb>0.6</td><td class=ubb>4</td><td class=ubb>174</td><td class=ubb>NPN</td><td class=ubb>SI</td><td class=ubb>-</td><td class=ubb>2755</td></TR><TR><td class=ubb>2756</td><td class=ubb>IRF240</td><td class=ubb>IRF</td><td class=ubb>240</td><td class=ubb>1000</td><td class=ubb>18</td><td class=ubb>125</td><td class=ubb>-</td><td class=ubb>N-FET</td><td class=ubb>N-FET</td><td class=ubb>-</td><td class=ubb>2756</td></TR><TR><td class=ubb>2757</td><td class=ubb>IRFP240</td><td class=ubb>IRF</td><td class=ubb>P240</td><td class=ubb>1000</td><td class=ubb>20</td><td class=ubb>150</td><td class=ubb>-</td><td class=ubb>N-FET</td><td class=ubb>N-FET</td><td class=ubb>0,18&nbsp;Ohm</td><td class=ubb>2757</td></TR><TR><td class=ubb>2758</td><td class=ubb>GD243</td><td class=ubb>GD243</td><td class=ubb>GD243</td><td class=ubb>1000</td><td class=ubb>3</td><td class=ubb>10</td><td class=ubb>-</td><td class=ubb>PNP</td><td class=ubb>GE</td><td class=ubb>-</td><td class=ubb>2758</td></TR><TR><td class=ubb>2759</td><td class=ubb>MJE243</td><td class=ubb>MJ</td><td class=ubb>243</td><td class=ubb>1000</td><td class=ubb>4</td><td class=ubb>15</td><td class=ubb>40</td><td class=ubb>NPN</td><td class=ubb>SI</td><td class=ubb>-</td><td class=ubb>2759</td></TR><TR><td class=ubb>2760</td><td class=ubb>BS250</td><td class=ubb>BS250</td><td class=ubb>BS250</td><td class=ubb>1000</td><td class=ubb>0.18</td><td class=ubb>0.83</td><td class=ubb>-</td><td class=ubb>P-FET</td><td class=ubb>P-FET</td><td class=ubb>-</td><td class=ubb>2760</td></TR><TR><td class=ubb>2761</td><td class=ubb>IRF250</td><td class=ubb>IRF</td><td class=ubb>250</td><td class=ubb>1000</td><td class=ubb>30</td><td class=ubb>150</td><td class=ubb>-</td><td class=ubb>N-FET</td><td class=ubb>N-FET</td><td class=ubb>-</td><td class=ubb>2761</td></TR><TR><td class=ubb>2762</td><td class=ubb>IRFP250</td><td class=ubb>IRF</td><td class=ubb>P250</td><td class=ubb>1000</td><td class=ubb>33</td><td class=ubb>180</td><td class=ubb>-</td><td class=ubb>N-FET</td><td class=ubb>N-FET</td><td class=ubb>-</td><td class=ubb>2762</td></TR><TR><td class=ubb>2763</td><td class=ubb>MJE253</td><td class=ubb>MJ</td><td class=ubb>253</td><td class=ubb>1100</td><td class=ubb>4</td><td class=ubb>15</td><td class=ubb>40</td><td class=ubb>PNP</td><td class=ubb>SI</td><td class=ubb>-</td><td class=ubb>2763</td></TR><TR><td class=ubb>2764</td><td class=ubb>BSN254A</td><td class=ubb>BSN</td><td class=ubb>254A</td><td class=ubb>1100</td><td class=ubb>0.3</td><td class=ubb>1</td><td class=ubb>-</td><td class=ubb>N-FET</td><td class=ubb>N-FET</td><td class=ubb>7&nbsp;Ohm</td><td class=ubb>2764</td></TR><TR><td class=ubb>2765</td><td class=ubb>MJE270</td><td class=ubb>MJ</td><td class=ubb>270</td><td class=ubb>1100</td><td class=ubb>2</td><td class=ubb>15</td><td class=ubb>16</td><td class=ubb>N-DARL</td><td class=ubb>N-DARL</td><td class=ubb>-</td><td class=ubb>2765</td></TR><TR><td class=ubb>2766</td><td class=ubb>MJE271</td><td class=ubb>MJ</td><td class=ubb>271</td><td class=ubb>1100</td><td class=ubb>2</td><td class=ubb>15</td><td class=ubb>-</td><td class=ubb>P-DARL</td><td class=ubb>P-DARL</td><td class=ubb>-</td><td class=ubb>2766</td></TR><TR><td class=ubb>2767</td><td class=ubb>BSN274</td><td class=ubb>BSN</td><td class=ubb>274</td><td class=ubb>1100</td><td class=ubb>0.25</td><td class=ubb>1</td><td class=ubb>-</td><td class=ubb>N-FET</td><td class=ubb>N-FET</td><td class=ubb>8&nbsp;Ohm</td><td class=ubb>2767</td></TR><TR><td class=ubb>2768</td><td class=ubb>J300</td><td class=ubb>J300</td><td class=ubb>J300</td><td class=ubb>1100</td><td class=ubb>0.006</td><td class=ubb>0.35</td><td class=ubb>-</td><td class=ubb>N-FET</td><td class=ubb>N-FET</td><td class=ubb>-</td><td class=ubb>2768</td></TR><TR><td class=ubb>2769</td><td class=ubb>BSN304</td><td class=ubb>BSN</td><td class=ubb>304</td><td class=ubb>1100</td><td class=ubb>0.25</td><td class=ubb>1</td><td class=ubb>-</td><td class=ubb>N-FET</td><td class=ubb>N-FET</td><td class=ubb>8&nbsp;Ohm</td><td class=ubb>2769</td></TR><TR><td class=ubb>2770</td><td class=ubb>J309</td><td class=ubb>J309</td><td class=ubb>J309</td><td class=ubb>1200</td><td class=ubb>0.03</td><td class=ubb>-</td><td class=ubb>-</td><td class=ubb>N-FET</td><td class=ubb>N-FET</td><td class=ubb>-</td><td class=ubb>2770</td></TR><TR><td class=ubb>2771</td><td class=ubb>J310</td><td class=ubb>J310</td><td class=ubb>J310</td><td class=ubb>1200</td><td class=ubb>0.06</td><td class=ubb>-</td><td class=ubb>-</td><td class=ubb>N-FET</td><td class=ubb>N-FET</td><td class=ubb>-</td><td class=ubb>2771</td></TR></table>
参考一下
<table class=ubb cellspacing=0><TR><td class=ubb>1</td><td class=ubb>型号</td><td class=ubb>型号1</td><td class=ubb>型号2</td><td class=ubb>电压</td><td class=ubb>最大电流</td><td class=ubb>最大功率</td><td class=ubb>频率</td><td class=ubb>极性</td><td class=ubb>材料</td><td class=ubb>沟道电阻</td><td class=ubb>1</td><td class=ubb></td></TR></table><br />&nbsp;<br />
参考一下,晕,怎马发了3个
lyjian 发表于 2007-8-3 11:43 | 显示全部楼层
什么破表,乱七八糟,参数都不对
computer00 发表于 2007-8-3 11:52 | 显示全部楼层
这里也有几张表
  <br /> 相关链接:<a href='http://computer00.21ic.org/user1/2198/archives/2006/11028.html'>http://computer00.21ic.org/user1/2198/archives/2006/11028.html</a>
tyw 发表于 2007-8-3 12:53 | 显示全部楼层
少累哈,这两天贴图的不行,你就将就点了拉,哈哈
<br /><img src="https://bbs.21ic.com/upfiles/img/20078/200783125219589.gif"><img src="https://bbs.21ic.com/upfiles/img/20078/200783125219589.gif"><img src="https://bbs.21ic.com/upfiles/img/20078/200783125219589.gif"><img src="https://bbs.21ic.com/upfiles/img/20078/200783125219589.gif"><img src="https://bbs.21ic.com/upfiles/img/20078/200783125219589.gif"><br /><br />晕,能贴了<br /><img src="https://bbs.21ic.com/upfiles/img/20078/20078312585588.gif"><br /><img src="https://bbs.21ic.com/upfiles/img/20078/200783125851687.gif">
 楼主| xuhui_tjut 发表于 2007-8-20 10:35 | 显示全部楼层
谢谢阿
谢谢啊,找这样的三极管找的好苦啊
 楼主| xuhui_tjut 发表于 2007-8-20 11:05 | 显示全部楼层
晕死了
上面好多数据是错的<br />
dangerb_cn 发表于 2007-8-21 10:28 | 显示全部楼层
参考下
就是给个参考<br />你可以自己再里面淘金啊<br />现在这器件不是天天在变么
