ADC多通道的问题
2566|1
 楼主| isd2560 发表于 2008-12-10 12:05 | 显示全部楼层 |阅读模式
采样出来的数据一直在跳,不稳定啊,万利199的板子
打开通道10到16通道,采用自动连续转换模式,转换完一个通道的数据由DMA送到内存中ADC_RCVTab,然后我把通道10的数据送到串口显示,出现如下问题:
1;如果采用多通道,但是没使能DMA内存增量模式时:采样电压跳动比单通道幅度要大(我AD采样的是均值滤波器,定时1ms采一个,单周期采16个),单通道时跳动很小,土1位。
2:如果采用多通道,使能DMA内存增量模式时:通道10采样电压接近3.29V(外用表测为1.8几V),LED都亮了,似乎程序跑飞。
问:如何纠正这种情况,使测试数据正常?
以下为部分程序:
  /* DMA channel1 configuration ----------------------------------------------*/
  DMA_DeInit(DMA_Channel1);
  DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;
  DMA_InitStructure.DMA_MemoryBaseAddr = (u32)ADC_RCVTab;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
  DMA_InitStructure.DMA_BufferSize = 140;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  DMA_Init(DMA_Channel1, &DMA_InitStructure);
  /* Enable DMA channel1 */
  DMA_Cmd(DMA_Channel1, ENABLE);
  /* ADC1 configuration ------------------------------------------------------*/
  ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
  ADC_InitStructure.ADC_ScanConvMode = ENABLE;
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  ADC_InitStructure.ADC_NbrOfChannel = 7;
  ADC_Init(ADC1, &ADC_InitStructure);
  /* ADC1 regular channel10 to 16 configuration */
  ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 2, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 3, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_13, 4, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 5, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_15, 6, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_16, 7, ADC_SampleTime_55Cycles5);
  /* Enable ADC1 DMA */
  ADC_DMACmd(ADC1, ENABLE);
  /* Enable ADC1 */
  ADC_Cmd(ADC1, ENABLE);
  /* Enable ADC1 reset calibaration register */
  ADC_ResetCalibration(ADC1);
  /* Check the end of ADC1 reset calibration register */
  while(ADC_GetResetCalibrationStatus(ADC1));
  /* Start ADC1 calibaration */
  ADC_StartCalibration(ADC1);
  /* Check the end of ADC1 calibration */
  while(ADC_GetCalibrationStatus(ADC1));
  ADC_TempSensorVrefintCmd(ENABLE);
  /* Start ADC1 Software Conversion */
  ADC_SoftwareStartConvCmd(ADC1, ENABLE);
 楼主| isd2560 发表于 2008-12-10 14:22 | 显示全部楼层
啊,晕哦
咋个木得人回呢?要多多照顾新手啊~~~
