排序算法总结
1144|8
 楼主| 東南博士 发表于 2015-9-20 14:31 | 显示全部楼层 |阅读模式
TI, While, TE, ge, se
有时候,我们在搞数据采集和算法的时候,需要及时的采集数据最大值,最小值或者其他数据关系。
我把我遇到的分享一下:
#     FileName: sort.c
#         Desc: Summary of the sort algorithm
#       Author: wusuopubupt
#        Email: wdxbupt2009_at_gmail_dot_com
#      Created: 2014-03-30
#include<stdio.h>
#include<stdlib.h>
#define MAX_HEAP_LEN 100
int heap[MAX_HEAP_LEN];
int heap_size = 0;
void swap(int *a, int *b);
void dump_arr(int *a, int n);
void selection_sort(int *arr, int n);
void insertion_sort(int *arr, int n);
void bubble_sort(int *arr, int n);
void quick_sort(int *arr, int low, int high);
void shell_sort(int *arr, int n);
void merge_sort(int *arr, int n);
void merge_array(int *a1, int a1_size, int *a2, int a2_size);
void heap_sort (int *arr, int n);
* main function
int main(void) {
        int n;
        while(scanf("%d", &n) != EOF) {
                int arr[n], i;
                for(i = 0; i < n; i++) {
                        scanf("%d", &arr);
                heap_sort(arr, n);
                //dump_arr(heap, n);
        return 0;
* swap a and b
void swap(int *a, int *b) {
        int temp = *a;
        *a = *b;
        *b = temp;
* dump an array
void dump_arr(int *a, int n) {
        int i;
                printf("%d ", a);
        putchar('\n');
* selection sort
* 每次从无序的n-i个数找到最小的数
* 并和第i(0<=i<n)个数交换
* 时间复杂度为O(n^2)
void selection_sort(int *a, int n) {
        int i, j, min, min_index;
                min = a;
                min_index = i;
                for(j = i+1; j < n; j++) {
                        if(a[j] < min) {
                                min = a[j];
                                min_index = j;
                swap(&a, &a[min_index]);
* insertion sort
* 将一个记录插入到已经排好序的有序表中, 从而得到一个新的,记录数增1的有序表
void insertion_sort(int *a, int n) {
        int i, j, temp;
        for(i = 1; i < n; i++) {
                temp = a;
                j = i - 1;
                while(j >= 0 && temp < a[j]) {
                        a[j+1] = a[j];
                        j--;
                a[j+1] = temp;
/* bubble sort
*两两比较相邻记录的关键字,如果反序则交换
void bubble_sort(int *a, int n) {
        int i, j;
        for(i = n-1; i >= 0; i--) {
                for(j = 0; j < i; j++) {
                        if(a[j+1] < a[j]) {
                                swap(&a[j+1], &a[j]);
* quick sort(Digging and filling)
* 快速排序不稳定
void quick_sort(int *a, int low, int high) {
        int mid = (low + high) / 2;
        int i = low, j = high;
        int pivot = a[mid];
        while(i < j) {
                while(i <= mid && a < pivot) {
                        i++;
                if(i < mid) {
                        a[mid] = a;
                        mid = i;
                while(j >= mid && a[j] > pivot) {
                        j--;
                if(j > mid) {
                        a[mid] = a[j];
                        mid = j;
        a[mid] = pivot;
        //recursive
        if(mid > low) {
                quick_sort(a, low, mid-1);
        if(mid < high) {
                quick_sort(a, mid+1, high);
* shell sort
* 先将整个待排元素序列分割成若干子序列(由相隔某个“增量”的元素组成的)分别进行
* 直接插入排序,然后依次缩减增量再进行排序,待整个序列中的元素基本有序(增量足够小,gap == 1)时,
* 再对全体元素进行一次直接插入排序。其时间复杂度为O(n^3/2),要好于直接插入排序的O(n^2)
void shell_sort(int a[], size_t n) {
        int gap;
        for(gap = n/2; gap > 0; gap /= 2) {
                int i;
                for(i = gap; i < n; i++) {
                        if(a < a[i-gap]) {
                                int j = i - gap;
                                int temp = a;
                                while(j >= 0 && a[j] > a) {
                                        a[j+gap] = a[j];
                                        j -= gap;
                                a[j+gap] = temp;
* merge sort
* 分治、递归
void merge_sort(int *a, int n) {
        if(n > 1) {
                int *a1 = a; //注意a1和a的地址是一样的
                int a1_size = n / 2;
                int *a2 = a + n / 2;
                int a2_size = n - a1_size;
                merge_sort(a1, a1_size);
                merge_sort(a2, a2_size);
                merge_array(a1, a1_size, a2, a2_size);
void merge_array(int *a1, int a1_size, int *a2, int a2_size) {
        int i, j, k, n;
        i = j = k = 0;
        n = a1_size + a2_size;
        int a[n];
        while(i < a1_size && j < a2_size) {
                // 把较小的那个数据放到结果数组里, 同时移动指针
                a[k++] = a1 < a2[j] ? a1[i++] : a2[j++];
        // 如果 list1 还有元素,把剩下的数据直接放到结果数组
        while(i < a1_size) {
                a[k++] = a1[i++];
        //反之, 如果 list1 还有元素,把剩下的数据直接放到结果数组
        while(j < a2_size) {
                a[k++] = a2[j++];
        // 把结果数组 copy 到 list1 里
        for(i = 0; i < n; ++i) {
                a1 = a;
* heap sort(最小堆)
* 堆的特点:
* 父节点i的左子节点在位置 (2*i+1);
* 父节点i的右子节点在位置 (2*i+2);
* 子节点i的父节点在位置 floor((i-1)/2);
void shift_up(int i) {
        int done = 0;
        if(i == 0) {
                return; //root
        while((i != 0) && (!done)) {
                if(heap < heap[(i-1)/2]) {
                        swap(&heap, &heap[(i-1)/2]);
                else {
                        done = 1;
                i = (i-1) / 2; //parent
void shift_down(int i) {
        int done = 0;
        //没有左子结点,即为叶节点
        if(2*i+1 > heap_size) {
                return;
        while((2*i+1 < heap_size) && (!done)) {
                i = 2*i + 1; //jump to left child
                if((i+1 < heap_size) && heap[i+1] > heap) {
                        i++;
                if(heap[(i-1)/2] > heap) {
                        swap(&heap[(i-1)/2], &heap);
                else{
                        done = 1;
void delete(int i) {
        int last = heap[heap_size - 1];
        heap_size--;
        if(i == heap_size) {
                return;
        heap = last;
        shift_down(i);
int delete_min() {
        int ret = heap[0];
        delete(0);
        return ret;
void insert(int new_data) {
        if(heap_size >= MAX_HEAP_LEN) {
                return;
        heap_size++;
        heap[heap_size - 1] = new_data;
        shift_up(heap_size - 1);
void heap_sort(int *a, int n) {
        int i;
                insert(a);
        dump_arr(heap, n);
zhangbo1985 发表于 2015-9-20 17:08 | 显示全部楼层
这么多算法的,最基本的还是比较排序的。
zhangbo1985 发表于 2015-9-20 17:10 | 显示全部楼层
这些算法的收起来的,处理大数据量的非常实用。
tongbu2015 发表于 2015-9-20 22:18 | 显示全部楼层
这些排序算法的都比较常用。
冰河w 发表于 2015-9-21 19:37 | 显示全部楼层
感谢分享
 楼主| 東南博士 发表于 2015-9-25 14:38 | 显示全部楼层
比较常用
baimiaocun2015 发表于 2015-9-26 15:32 | 显示全部楼层
我记得有一个叫冒泡排序法的,很有用的额。
 楼主| 東南博士 发表于 2015-9-28 21:45 | 显示全部楼层
是吗?你说如果找一个数组的最大值,这个好找吗?
598330983 发表于 2015-9-30 23:13 来自手机 | 显示全部楼层
基础算法,考试面试必备
