请教香主,如何启动DMA传输?
3694|10
 楼主| zhangxk 发表于 2009-4-11 10:03 | 显示全部楼层 |阅读模式
我用DMA发送串口数据,如何启动传输呢,是要专门设置定时器启动吗?
香水城 发表于 2009-4-11 10:33 | 显示全部楼层
软件启动DMA,然后每当发送寄存器空时,DMA传送一次数据
详见STM32参考手册的24.3.12节。
smallfishyjt 发表于 2009-4-11 18:27 | 显示全部楼层
看你想怎么启动了
DMA的启动方式有很多中种的
如果你需要定时来启动就用定时器来启动
但是从你说的来看是想通过串口的收发来启动传输
可以看一下USART里面的DMA模式
 楼主| zhangxk 发表于 2009-4-12 10:45 | 显示全部楼层
还是不启动
按照参考手册和例程程序的顺序都试了,还是不能启动传输。
初始化程序:
    GPIO_InitTypeDef  GPIO_InitStructure;
    USART_InitTypeDef USART_InitStructure;
     /* Configure USARTx_Tx as alternate function push-pull */
    GPIO_InitStructure.GPIO_Pin = GPIOA_Tx1Pin;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    /* Configure USARTx_Rx as input floating */
    GPIO_InitStructure.GPIO_Pin = GPIOA_Rx1Pin;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    DMA_UART1Tx_StructInit();
    DMA_Init(DMA1_Channel4, &DMA_UART1TxStructure);
    BSP_IntVectSet(BSP_INT_ID_DMA1_CH4, DMA1_CH4_Uart1TxFinish);
    BSP_IntPrioSet(BSP_INT_ID_DMA1_CH4, DMA1_CH4_UART1Tx_UIP);
    BSP_IntEn(BSP_INT_ID_DMA1_CH4);
    /* USARTx configuration ------------------------------------------------------*/
    /* USARTx configured as follow:
         - BaudRate = 115200 baud
         - Word Length = 8 Bits
         - One Stop Bit
         - No parity
         - Hardware flow control disabled (RTS and CTS signals)
         - Receive and transmit enabled
    USART_InitStructure.USART_BaudRate = 115200;
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;
    USART_InitStructure.USART_StopBits = USART_StopBits_1;
    USART_InitStructure.USART_Parity = USART_Parity_No ;
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
    USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
    USART_Init(USART1, &USART_InitStructure);
    USART_DMACmd(USART1, USART_DMAReq_Tx, ENABLE);
发送子程序:
    DMA_Cmd(DMA1_Channel4, DISABLE);
    DMA_UART1TxStructure.DMA_MemoryBaseAddr = (u32)TxBuf;
    DMA_UART1TxStructure.DMA_BufferSize = temp;
    DMA_Cmd(DMA1_Channel4, ENABLE);
    USART_Cmd(USART1, ENABLE);
这样还是不行,运行后没有数据从串口发出去。
 楼主| zhangxk 发表于 2009-4-12 12:11 | 显示全部楼层
找到了问题的原因
问题出在了 DMA_UART1TxStructure.DMA_PeripheralBaseAddr 这个地址变量的赋值上,我是这样操作的:
DMA_UART1TxStructure.DMA_PeripheralBaseAddr = (u32)USART1->DR;
这样也试过:
DMA_UART1TxStructure.DMA_PeripheralBaseAddr = USART1->DR;
两种方式的结果 DMA_PeripheralBaseAddr 都是 0。
后来我直接地址赋值问题就解决了:
DMA_UART1TxStructure.DMA_PeripheralBaseAddr = 0x40013804;
USART1->DR 是接收数据寄存器地址,为什么它的地址值是 0 呢?
lut1lut 发表于 2009-4-13 11:53 | 显示全部楼层
拜托,一个是内容,一个是地址
 楼主| zhangxk 发表于 2009-4-13 12:42 | 显示全部楼层
是的,问题解决了,谢谢
btyang 发表于 2009-9-9 14:52 | 显示全部楼层
请问香主你的STM32 手册能不能给个下载链接 啊
我想看看
谢谢
香水城 发表于 2009-9-9 23:48 | 显示全部楼层
我想看看
谢谢
请看置顶帖“如何查找STM32的官方文档
btyang 发表于 2009-9-10 19:48 | 显示全部楼层
谢谢香主,香主万岁
无冕之王 发表于 2009-9-10 23:33 | 显示全部楼层
学习中。。。
