我的nandFalsh操作还是有问题,但用IO模拟总线的是可以读出ID
3427|12
 楼主| hz_richard 发表于 2009-7-27 09:48 | 显示全部楼层 |阅读模式
我的nandFalsh操作还是有问题,但用IO模拟总线的是可以读出ID的
请问哪位老兄能帮我一下,我全总是按ST的的例子来的。。不知道是哪里出现了问题,,,,我用的FLASH也是跟ST的型号一样。。
 楼主| hz_richard 发表于 2009-7-27 09:56 | 显示全部楼层
问一下,NAND flash有特别要注意的地方吗?
哪位能把你的初始化部份过给我看看,谢谢我觉得硬件跟ST的一样,那我软件也不需要什么改动呀
 楼主| hz_richard 发表于 2009-7-27 10:08 | 显示全部楼层
我先把程序部分贴出来
void FSMC_NAND_Init(void)
  GPIO_InitTypeDef GPIO_InitStructure;
  FSMC_NANDInitTypeDef FSMC_NANDInitStructure;
  FSMC_NAND_PCCARDTimingInitTypeDef  p;
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE |
                         RCC_APB2Periph_GPIOF | RCC_APB2Periph_GPIOG, ENABLE);
/*-- GPIO Configuration ------------------------------------------------------*/
/* CLE, ALE, D0->D3, NOE, NWE and NCE2  NAND pin configuration  */
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_14 | GPIO_Pin_15 |
                                 GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_4 | GPIO_Pin_5 |
                                 GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
/* D4->D7 NAND pin configuration  */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10;
  GPIO_Init(GPIOE, &GPIO_InitStructure);
/* NWAIT NAND pin configuration */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
/* INT2 NAND pin configuration */
 // GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
  //GPIO_Init(GPIOG, &GPIO_InitStructure);
  /*-- FSMC Configuration ------------------------------------------------------*/
  p.FSMC_SetupTime = 0x1;
  p.FSMC_WaitSetupTime = 0x3;
  p.FSMC_HoldSetupTime = 0x2;
  p.FSMC_HiZSetupTime = 0x1;
  FSMC_NANDInitStructure.FSMC_Bank = FSMC_Bank2_NAND;
  FSMC_NANDInitStructure.FSMC_Waitfeature = FSMC_Waitfeature_Enable;
  FSMC_NANDInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_8b;
  FSMC_NANDInitStructure.FSMC_ECC = FSMC_ECC_Enable;
  FSMC_NANDInitStructure.FSMC_ECCPageSize = FSMC_ECCPageSize_512Bytes;
  FSMC_NANDInitStructure.FSMC_AddressLowMapping = FSMC_AddressLowMapping_Direct;
  FSMC_NANDInitStructure.FSMC_TCLRSetupTime = 0x00;
  FSMC_NANDInitStructure.FSMC_TARSetupTime = 0x00;
  FSMC_NANDInitStructure.FSMC_CommonSpaceTimingStruct = &p;
  FSMC_NANDInitStructure.FSMC_AttributeSpaceTimingStruct = &p;
  FSMC_NANDInit(&FSMC_NANDInitStructure);
  /* FSMC NAND Bank Cmd Test */
  FSMC_NANDCmd(FSMC_Bank2_NAND, ENABLE);
ST_ARM 发表于 2009-7-27 10:26 | 显示全部楼层
这个使能了么?
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC, ENABLE);
 楼主| hz_richard 发表于 2009-7-27 11:39 | 显示全部楼层
全能了,是在主程序里使用的
 楼主| hz_richard 发表于 2009-7-27 11:43 | 显示全部楼层
我改用IO模拟,是可以读出ID(0x20 0x76),
我一开始怕nand坏了,我改用IO模拟,是可以读出ID(0x20 0x76),所以硬件应该不会有问题
 楼主| hz_richard 发表于 2009-7-27 11:48 | 显示全部楼层
我说明一下
R/B接的是PD6(FSMC_NWAIT)
NAND型号是Nand512W3a2(跟ST的原理图一下)
ST_ARM 发表于 2009-7-27 15:35 | 显示全部楼层
改一下这个试一试。
p.FSMC_WaitSetupTime = 0x2;
 楼主| hz_richard 发表于 2009-7-27 15:56 | 显示全部楼层
试了,不过失败了,请问哪位还有什么思路呀,非常感谢
 楼主| hz_richard 发表于 2009-7-27 16:56 | 显示全部楼层
香主,请问一下,
在官方下载的例程:examples/FSMC/NAND这个程序在官方的板子上应该是没有问题的吧?我想确认一下。。。
ST_ARM 发表于 2009-7-27 17:20 | 显示全部楼层
 楼主| hz_richard 发表于 2009-7-27 20:21 | 显示全部楼层
那我只能说是Nand换了,
其实这应该很简单的呀,难道的NAND坏了?,实在是找不到其他原因了。明天换一个去。。。。
香水城 发表于 2009-7-27 21:06 | 显示全部楼层
你能用示波器看看,是否有信号出来?
