用最新库玩转智林STM32开发板(之九)--在真彩屏上显示方向键
2553|2
 楼主| ddllxxrr 发表于 2009-5-2 13:37 | 显示全部楼层 |阅读模式
有智林板的可以把所有文件考到一个目录下边,工程非常简单只包括三个文件
main.C//主文件
TFT018.c//显示有关文件
STM32F10XR.LIB//这个文件在MDK目录下边很好找
智林开发板板载上,下,左,右,方向键,若直接按,就是OK,本程序只是设置好上拉电阻输入就行,
运行时可即时显示用户的按键,本例有HEX可直接下载到芯片里边
以下是主程序:
int main(void)
#ifdef DEBUG
  debug();
#endif
  /* System Clocks Configuration */
  RCC_Configuration();
  /* NVIC Configuration */
  NVIC_Configuration();
  /* GPIO Configuration */
  GPIO_Configuration();
  /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 0x5000;
  TIM_TimeBaseStructure.TIM_Prescaler = 0x00;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  /* Output Compare Toggle Mode configuration: Channel1 */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse =CCR3_Val ;
  TIM_OC3Init(TIM2, &TIM_OCInitStructure);
  /* TIM enable counter */
  TIM_Cmd(TIM2, ENABLE);
  LCD_Init();
  LCD_Clear_Screen(Blue);
  while(1)
  for(;;) {
    Font = 0;
    LCD_PutString(30,0,"STM32F 开发板",Cyan,Blue);
    LCD_PutString(30,16,"GPIO 输入演示",Red,Yellow);
    Font = 1;
    LCD_PutString(38,32,"Version 1.0",Green,Blue);
    Font = 0;
    LCD_PutString(10,94,"智林测控技术研究所",Yellow,Blue);
    LCD_PutString(36,111,"www.the0.net",Magenta,Blue);
    if (((GPIOB->IDR & JOYSTICK) == JOYSTICK ))  {   // Check if JOYSTICK key is pressed
      GPIOB->ODR &= ~LED;                         // switch off LED
else  {                                       // JOYSTICK key is pressed
      GPIOB->ODR |=  LED;                         // switch on LED
    if (((GPIOB->IDR & UP) == 0 ))              // Check if UP is pressed
      LCD_PutString(48,40,"上",Yellow,Red);
    else
      LCD_PutString(48,40,"上",Red,Yellow);
    if (((GPIOB->IDR & DOWN) == 0 ))            // Check if DOWN is pressed
      LCD_PutString(48,76,"下",Yellow,Red);
else
      LCD_PutString(48,76,"下",Red,Yellow);
    if (((GPIOB->IDR & LEFT) == 0 ))            // Check if LEFT is pressed
   LCD_PutString(30,58,"左",Yellow,Red);
else
   LCD_PutString(30,58,"左",Red,Yellow);
    if (((GPIOB->IDR & RIGHT) == 0 ))           // Check if RIGHT is pressed
      LCD_PutString(66,58,"右",Yellow,Red);
else
      LCD_PutString(66,58,"右",Red,Yellow);
    if (((GPIOB->IDR & OK) == 0 ))              // Check if OK is pressed
      LCD_PutString(48,58,"OK",Yellow,Red);
else
      LCD_PutString(48,58,"OK",Red,Yellow);
    if (((GPIOC->IDR & BP2) == 0 ))            // Check if BP2 is not pressed
      LCD_PutString(100,40,"BP2",Yellow,Red);
else
      LCD_PutString(100,40,"BP2",Red,Yellow);
    if (((GPIOA->IDR & BP3) == 0 ))            // Check if BP3 is not pressed
      LCD_PutString(100,76,"BP3",Yellow,Red);
else
      LCD_PutString(100,76,"BP3",Red,Yellow);
McuPlayer 发表于 2009-5-2 14:15 | 显示全部楼层
建议楼主把自己的几个帖子合并,做连载
 楼主| ddllxxrr 发表于 2009-5-2 21:21 | 显示全部楼层
兄弟建议不错,只是我是个懒人,等有机会我再整一下
