[i.MX] 关于 imx6sololite DDR3测试问题
2826|6
 楼主| LXingJian 发表于 2015-9-28 16:04 | 显示全部楼层 |阅读模式
Hi Rita:
1.下面是我的配置文件:
//init script for i.MX6SL DDR3
// Revision History
// v0.7
wait = on
// Disable        WDOG
//setmem /16        0x020bc000 =        0x30
// Enable all clocks (they are disabled by ROM code)
setmem /32        0x020c4068 =        0xffffffff
setmem /32        0x020c406c =        0xffffffff
setmem /32        0x020c4070 =        0xffffffff
setmem /32        0x020c4074 =        0xffffffff
setmem /32        0x020c4078 =        0xffffffff
setmem /32        0x020c407c =        0xffffffff
setmem /32        0x020c4080 =        0xffffffff
setmem /32        0x020c4084 =        0xffffffff
setmem /32        0x020c4018 =        0x00260324        //DDR clk to 400MHz
// IOMUX
//DDR IO TYPE:
setmem /32        0x020e05c0 =        0x00020000        // IOMUXC_SW_PAD_CTL_GRP_DDRMODE
setmem /32        0x020e05b4 =        0x00000000        // IOMUXC_SW_PAD_CTL_GRP_DDRPKE
//CLOCK:
setmem /32        0x020e0338 =        0x00000030        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDCLK_0
//Control:
setmem /32        0x020e0300 =        0x00000030        // IOMUXC_SW_PAD_CTL_PAD_DRAM_CAS
setmem /32        0x020e031c =        0x00000030        // IOMUXC_SW_PAD_CTL_PAD_DRAM_RAS
setmem /32        0x020e0320 =        0x00000030        // IOMUXC_SW_PAD_CTL_PAD_DRAM_RESET
setmem /32        0x020e032c =        0x00000000        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDBA2 - DSE can be configured using Group Control Register: IOMUXC_SW_PAD_CTL_GRP_CTLDS
//setmem /32        0x020e033c =        0x00000030        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDODT0
//setmem /32        0x020e0340 =        0x00000030        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDODT1
setmem /32        0x020e05ac =        0x00000030        // IOMUXC_SW_PAD_CTL_GRP_ADDDS
setmem /32        0x020e05c8 =        0x00000030        // IOMUXC_SW_PAD_CTL_GRP_CTLDS
//Data Strobes:
setmem /32        0x020e05b0 =        0x00020000        // IOMUXC_SW_PAD_CTL_GRP_DDRMODE_CTL
setmem /32        0x020e0344 =        0x00000030        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS0
setmem /32        0x020e0348 =        0x00000030        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS1
setmem /32        0x020e034c =        0x00000030        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS2
setmem /32        0x020e0350 =        0x00000030        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS3
//Data:
setmem /32        0x020e05d0 =        0x000C0000        // IOMUXC_SW_PAD_CTL_GRP_DDR_TYPE
setmem /32        0x020e05c4 =        0x00000030        // IOMUXC_SW_PAD_CTL_GRP_B0DS
setmem /32        0x020e05cc =        0x00000030        // IOMUXC_SW_PAD_CTL_GRP_B1DS
setmem /32        0x020e05d4 =        0x00000030        // IOMUXC_SW_PAD_CTL_GRP_B2DS
setmem /32        0x020e05d8 =        0x00000030        // IOMUXC_SW_PAD_CTL_GRP_B3DS
setmem /32        0x020e030c =        0x00000030        // IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM0
setmem /32        0x020e0310 =        0x00000030        // IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM1
setmem /32        0x020e0314 =        0x00000030        // IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM2
setmem /32        0x020e0318 =        0x00000030        // IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM3
// DDR Controller Registers
// Manufacturer:        SAMSUNG
// Device Part Number:        K4B2G1646Q-BCK0
// Clock Freq.:         400MHz
// Density per CS in Gb:         4
// Chip Selects used:        1
// Total DRAM density (Gb)        4
// Number of Banks:        8
// Row address:            14
// Column address:         10
// Data bus width        32
setmem /32        0x021b0800 =        0xa1390003         // DDR_PHY_P0_MPZQHWCTRL, enable both one-time & periodic HW ZQ calibration.
// write leveling, based on Freescale board layout and T topology
// For target board, may need to run write leveling calibration
// to fine tune these settings
// If target board does not use T topology, then these registers
// should either be cleared or write leveling calibration can be run
setmem /32        0x021b080c =         0x001F001F
setmem /32        0x021b0810 =         0x001F001F
//calibration values based on calibration compare of 0x00ffff00:
//Note, these calibration values are based on Freescale's board
//May need to run calibration on target board to fine tune these
setmem /32        0x021b083c =        0x407E007F        // MPDGCTRL0 PHY0
setmem /32        0x021b0840 =        0x00690069        // MPDGCTRL1 PHY0
setmem /32        0x021b0848 =        0x42424645        // MPRDDLCTL PHY0  ******************
setmem /32        0x021b0850 =        0x3B383630        // MPWRDLCTL PHY0  ******************
setmem /32        0x021b081c =        0x33333333        // DDR_PHY_P0_MPREDQBY0DL3
setmem /32        0x021b0820 =        0x33333333        // DDR_PHY_P0_MPREDQBY1DL3
setmem /32        0x021b0824 =        0x33333333        // DDR_PHY_P0_MPREDQBY2DL3
setmem /32        0x021b0828 =        0x33333333        // DDR_PHY_P0_MPREDQBY3DL3
// Complete calibration by forced measurement:
setmem /32        0x021b08b8 =        0x00000800         // DDR_PHY_P0_MPMUR0, frc_msr
setmem /32        0x021b0004 =        0x00020024        // MMDC0_MDPDC
setmem /32        0x021b0008 =        0x00333040        // MMDC0_MDOTC
setmem /32        0x021b000c =        0x3F435313        // MMDC0_MDCFG0
setmem /32        0x021b0010 =        0xB68E8B63        // MMDC0_MDCFG1
setmem /32        0x021b0014 =        0x01FF00DB        // MMDC0_MDCFG2
setmem /32        0x021b0018 =        0x00081740        // MMDC0_MDMISC
setmem /32        0x021b001c =        0x00008000        // MMDC0_MDSCR, set the Configuration request bit during MMDC set up
setmem /32        0x021b002c =        0x000026d2        // MMDC0_MDRWD; recommend to maintain the default values
setmem /32        0x021b0030 =        0x00431023        // MMDC0_MDOR
setmem /32        0x021b0040 =        0x0000004F        // CS0_END
setmem /32        0x021b0000 =        0x83190000        // MMDC0_MDCTL
// Mode register writes
setmem /32        0x021b001c =        0x04008032        // MMDC0_MDSCR, MR2 write, CS0
setmem /32        0x021b001c =        0x00008033        // MMDC0_MDSCR, MR3 write, CS0
setmem /32        0x021b001c =        0x00048031        // MMDC0_MDSCR, MR1 write, CS0
setmem /32        0x021b001c =        0x05208030        // MMDC0_MDSCR, MR0 write, CS0
setmem /32        0x021b001c =        0x04008040        // MMDC0_MDSCR, ZQ calibration command sent to device on CS0
setmem /32        0x021b001c =        0x0400803A        // MMDC0_MDSCR, MR2 write, CS1
setmem /32        0x021b001c =        0x0000803B        // MMDC0_MDSCR, MR3 write, CS1
setmem /32        0x021b001c =        0x00048039        // MMDC0_MDSCR, MR1 write, CS1
setmem /32        0x021b001c =        0x05208038        // MMDC0_MDSCR, MR0 write, CS1
setmem /32        0x021b001c =        0x04008048        // MMDC0_MDSCR, ZQ calibration command sent to device on CS1
setmem /32        0x021b0020 =        0x00005800        // MMDC0_MDREF
setmem /32        0x021b0818 =        0x00011117        // DDR_PHY_P0_MPODTCTRL
setmem /32        0x021b0004 =        0x00025564        // MMDC0_MDPDC now SDCTL power down enabled
setmem /32        0x021b0404 =        0x00011006         //MMDC0_MAPSR ADOPT power down enabled
setmem /32        0x021b001c =        0x00000000        // MMDC0_MDSCR, clear this register (especially the configuration bit as initialization is complete)
我有跑好几种频率,都不行。
2.还有就是DRAM_RESET在加载配置文件之后没有拉到1.5V,还是0。
我有测买来的板子应该加载完之后是会被拉到1.5V的。
这边应该是受什么影响呢?
 楼主| LXingJian 发表于 2015-9-29 10:48 | 显示全部楼层
Hi:
我今天测电源时,发现USB_LDO_CAP只有2.5V,规格书写的是要输出3V。
请问这个电压是正常的吗?
 楼主| LXingJian 发表于 2015-9-29 10:50 | 显示全部楼层
向各位大神求救
mini1986 发表于 2015-10-9 09:20 | 显示全部楼层
你的ddr是参考官方的板子来的么......如果不是的话,调试起ddr来就很费劲了,好多参数,你都需要去配置......
 楼主| LXingJian 发表于 2015-10-9 09:32 | 显示全部楼层
问题找到了,是硬件上的问题。
shengzhaodong 发表于 2015-11-27 19:51 | 显示全部楼层
问题找到了,是硬件上的问题。
楼主能说一下怎么测到是硬件问题的吗?
侣行天下 发表于 2015-11-28 20:27 | 显示全部楼层
线都是自己布的吗,还是在原来基础上改的?
