[技术问题解答] yocto 编译qt5.5.0出错
2248|1
 楼主| fhf123 发表于 2015-9-29 11:57 | 显示全部楼层 |阅读模式
ERROR: Function failed: do_configure (log file is located at /home/yocto/yocto_3.14.28-1.0.1/build/tmp/work/cortexa9hf-vfp-neon-mx6qdl-poky-linux-gnueabi/qtbase/5.5.0+gitAUTOINC+2fde9f59ee-r0/temp/log.do_configure.27644)
ERROR: Logfile of failure stored in: /home/yocto/build/tmp/work/cortexa9hf-vfp-neon-mx6qdl-poky-linux-gnueabi/qtbase/5.5.0+gitAUTOINC+2fde9f59ee-r0/temp/log.do_configure.27644
Log data follows:
| DEBUG: Executing python function sysroot_cleansstate
| DEBUG: Python function sysroot_cleansstate finished
| DEBUG: Executing shell function qmake5_base_preconfigure
| DEBUG: Shell function qmake5_base_preconfigure finished
| DEBUG: Executing shell function do_configure
| cp: cannot stat `/home/yocto/yocto_3.14.28-1.0.1/build/tmp/work/cortexa9hf-vfp-neon-mx6qdl-poky-linux-gnueabi/qtbase/5.5.0+gitAUTOINC+2fde9f59ee-r0/git/mkspecs/devices/linux-imx6-g++/qeglfshooks_imx6.cpp': No such file or directory
| WARNING: exit code 1 from a shell command.
没有qeglfshooks_imx6.cpp这个文件
doupengda 发表于 2018-7-27 17:49 | 显示全部楼层
你好,能把用yocto编译Qt5流程告诉我吗?
