[DemoCode下载]
NUC123 SPI 主仆角色使用PDMA传发资料
2429|2
a_ziliu|  楼主 | 2015-10-2 09:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
NUC123 SPI 主仆角色使用PDMA传发资料,
使用2颗晶片的SPI1对接即可.
NUC123SeriesBSP_CMSIS_V3.00.001 SPI PDMA MASTER WITH SLAVE.zip (366.45 KB)
734774645| | 2015-10-2 11:04 | 只看该作者
(⊙o⊙)哦,通过spi互相传啊
mintspring| | 2015-10-4 08:10 | 只看该作者
* @file     main.c
* @version  V2.00
* $Revision: 8 $
* $Date: 14/08/05 11:13a $
* @brief
*           Demonstrate SPI master loop back transfer.
*           This sample code needs to connect SPI0_MISO0 pin and SPI0_MOSI0 pin together.
*           It will compare the received data with transmitted data.
* @note
* Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NUC123.h"
#define TEST_COUNT             64
uint32_t g_au32SourceData[TEST_COUNT];
uint32_t g_au32DestinationData[TEST_COUNT];
volatile uint32_t PDMA_TEST_LENGTH = 64;
volatile uint8_t SrcArray[64];
volatile uint8_t DestArray[64];
uint32_t volatile u32IsTestOver = 0xFF;
/* Function prototype declaration */
void SYS_Init(void);
void SPI_Init(void);
#define DMA_SPI1_TX 2
#define DMA_SPI1_RX 3
unsigned char temp;
/* Main function */
int main(void)
                int i;
    /* Unlock protected registers */
    SYS_UnlockReg();
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Configure UART0: 115200, 8-bit word, no parity bit, 1 stop bit. */
    UART_Open(UART0, 115200);
        for (i=0;i<64;i++)
                SrcArray=i;
                DestArray=0;
          GPIO_SetMode(PA, BIT14, GPIO_PMD_OUTPUT);
    /* Init SPI */
    SPI_Init();
                SPI1->CNTRL |= SPI_CNTRL_FIFO_Msk;
                PDMA_Open(1 << DMA_SPI1_TX);
    PDMA_SetTransferCnt(DMA_SPI1_TX, PDMA_WIDTH_8, PDMA_TEST_LENGTH);
    PDMA_SetTransferAddr(DMA_SPI1_TX, (uint32_t)SrcArray, PDMA_SAR_INC, (uint32_t)&SPI1->TX[0], PDMA_DAR_FIX);
    PDMA_EnableInt(DMA_SPI1_TX, PDMA_IER_BLKD_IE_Msk);
    PDMA2->CSR = (PDMA2->CSR & ~(PDMA_CSR_MODE_SEL_Msk) | (0x2 << PDMA_CSR_MODE_SEL_Pos));
                PDMA_Open(1 << DMA_SPI1_RX);
    PDMA_SetTransferCnt(DMA_SPI1_RX, PDMA_WIDTH_8, PDMA_TEST_LENGTH);
    PDMA_SetTransferAddr(DMA_SPI1_RX, (uint32_t)&SPI1->RX[0], PDMA_SAR_FIX, (uint32_t)DestArray, PDMA_DAR_INC);
    PDMA_EnableInt(DMA_SPI1_RX, PDMA_IER_BLKD_IE_Msk);
    PDMA3->CSR = (PDMA3->CSR & ~(PDMA_CSR_MODE_SEL_Msk) | (0x1 << PDMA_CSR_MODE_SEL_Pos));
                PDMA_GCR->PDSSR0=0x0FF2301;
                NVIC_EnableIRQ(PDMA_IRQn);
          SPI_TRIGGER_RX_PDMA(SPI1);
          SPI_TRIGGER_TX_PDMA(SPI1);
                PDMA_Trigger(DMA_SPI1_RX);
                PDMA_Trigger(DMA_SPI1_TX);
    PA14=0;
          while(1)
                if(PA14==1)
                for(i=0;i<64;i++)
                if(SrcArray!=DestArray)
                        while(1);
                SrcArray=i;
                DestArray=0;
                PA14=0;
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable XT1_OUT (PF0) and XT1_IN (PF1) */
    SYS->GPF_MFP |= SYS_GPF_MFP_PF0_XT1_OUT | SYS_GPF_MFP_PF1_XT1_IN;
    /* Enable external 12MHz XTAL */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Switch HCLK clock source to HXT and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HXT, CLK_CLKDIV_HCLK(1));
    /* Select HXT as the clock source of UART0 */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    /* Select HCLK as the clock source of SPI0 */
    CLK_SetModuleClock(SPI1_MODULE, CLK_CLKSEL1_SPI1_S_HCLK, MODULE_NoMsk);
    /* Enable UART peripheral clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Enable SPI0 peripheral clock */
    CLK_EnableModuleClock(SPI1_MODULE);
   /* Enable PDMA module clock */
    CLK->AHBCLK |= CLK_AHBCLK_PDMA_EN_Msk;
    /* Init I/O Multi-function        */
    /* Set PB multi-function pins for UART0 RXD and TXD */
    SYS->GPB_MFP = SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD;
    /* Setup SPI0 multi-function pins */
    SYS->GPC_MFP = SYS_GPC_MFP_PC8_SPI1_SS0 | SYS_GPC_MFP_PC9_SPI1_CLK | SYS_GPC_MFP_PC10_SPI1_MISO0 | SYS_GPC_MFP_PC11_SPI1_MOSI0;
    SYS->ALT_MFP = SYS_ALT_MFP_PC8_SPI1_SS0 | SYS_ALT_MFP_PC9_SPI1_CLK | SYS_ALT_MFP_PC10_SPI1_MISO0 | SYS_ALT_MFP_PC11_SPI1_MOSI0;
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock and CyclesPerUs automatically. */
    SystemCoreClockUpdate();
void SPI_Init(void)
    /* Init SPI        */
    /* Configure as a master, clock idle low, 32-bit transaction, drive output on falling clock edge and latch input on rising edge. */
    /* Set IP clock divider. SPI clock rate = 2MHz */
    SPI_Open(SPI1, SPI_SLAVE, SPI_MODE_0, 8, 36000000);
    /* Enable the automatic hardware slave select function. Select the SS pin and configure as low-active. */
    SPI_EnableAutoSS(SPI1, SPI_SS0, SPI_SS_ACTIVE_LOW);
void PDMA_IRQHandler(void)
    uint32_t status = PDMA_GET_INT_STATUS();
    if(status & 0x1)    /* CH0 */
        if(PDMA_GET_CH_INT_STS(0) & 0x2)
        PDMA_CLR_CH_INT_FLAG(0, PDMA_ISR_BLKD_IF_Msk);
    else if(status & 0x2)      /* CH1 */
        if(PDMA_GET_CH_INT_STS(1) & 0x2)
        PDMA_CLR_CH_INT_FLAG(1, PDMA_ISR_BLKD_IF_Msk);
    else if(status & 0x4)      /* CH2 */
        if(PDMA_GET_CH_INT_STS(2) & 0x2)
                                        PA14=1;
        PDMA_CLR_CH_INT_FLAG(2, PDMA_ISR_BLKD_IF_Msk);
    else if(status & 0x8)      /* CH3 */
        if(PDMA_GET_CH_INT_STS(3) & 0x2)
        temp=1;
        PDMA_CLR_CH_INT_FLAG(3, PDMA_ISR_BLKD_IF_Msk);
    else if(status & 0x10)      /* CH4 */
        if(PDMA_GET_CH_INT_STS(4) & 0x2)
        PDMA_CLR_CH_INT_FLAG(4, PDMA_ISR_BLKD_IF_Msk);
    else if(status & 0x20)      /* CH5 */
        if(PDMA_GET_CH_INT_STS(5) & 0x2)
        PDMA_CLR_CH_INT_FLAG(5, PDMA_ISR_BLKD_IF_Msk);
    else
        printf("unknown interrupt !!\n");
/*** (C) COPYRIGHT 2014 Nuvoton Technology Corp. ***/
