它的FLASH为64K。<br />128K FLASH可以看看CodeFire的产品,MCF52230什么的。<br /><br />MCF52230 Features<br />Up to 57 Dhrystone 2.1 MIPS @ 60 MHz <br />eMAC Module and HW Divide <br />32K bytes SRAM <br />128K bytes Flash <br />100K W/E cycles, 10 years data retention <br />Integrated Peripherals <br />10/100 Ethernet MAC with PHY <br />3 UARTs <br />Queued Serial Peripheral Interface (QSPI) <br />I2C bus interface <br />4 ch. 32-bit timers with DMA support <br />4 ch. 16-Bit Capture/Compare/PWM timers <br />2 ch. Periodic Interrupt Timer <br />8ch. / 8-bit or 4ch. / 16-bit PWM timer <br />Real Time Clock <br />2 x 4 ch. 12-bit A-to-D converter <br />4 ch. DMA controller <br />Up to 73 General-Purpose I/O <br />System Integration (PLL, SW Watchdog) <br />Single 3.3V supply <br />Temperature Range: -40C to +85C <br />
