Device Phase Data Description Cmd.Phase.Ofs(rep) Delta Date Time <br />------ ----- -------------------------------------------------- ---------------- ------------------ ----- ---------- ------------<br /> 11.0 CTL a3 00 00 00 02 00 04 00 GET STATUS 1.1.0(2) 3.2mn 2006-10-04 15:23:12.365 <br /> 11.0 DI 01 01 01 00 .... 1.2.0 22us 2006-10-04 15:23:12.365 <br /> 11.0 CTL 23 01 10 00 02 00 00 00 CLEAR FEATURE 3.1.0 45us 2006-10-04 15:23:12.365 <br /> 11.0 CTL a3 00 00 00 01 00 04 00 GET STATUS 4.1.0 49us 2006-10-04 15:23:12.365 <br /> 11.0 DI 00 03 00 00 .... 4.2.0 13us 2006-10-04 15:23:12.365 <br /> 11.0 CTL a3 00 00 00 02 00 04 00 GET STATUS 5.1.0(2) 11us 2006-10-04 15:23:12.365 <br /> 11.0 DI 01 01 00 00 .... 5.2.0 13us 2006-10-04 15:23:12.365 <br /> 11.0 CTL 23 03 04 00 02 00 00 00 SET FEATURE 7.1.0 116ms 2006-10-04 15:23:12.481 <br /> 11.0 CTL a3 00 00 00 02 00 04 00 GET STATUS 8.1.0 26ms 2006-10-04 15:23:12.508 <br /> 11.0 DI 03 01 10 00 .... 8.2.0 32us 2006-10-04 15:23:12.508 <br /> 11.0 CTL 23 01 14 00 02 00 00 00 CLEAR FEATURE 9.1.0 6us 2006-10-04 15:23:12.508 <br /> 11.0 CTL a3 00 00 00 02 00 04 00 GET STATUS 10.1.0(2) 26ms 2006-10-04 15:23:12.534 <br /> 11.0 DI 03 01 00 00 .... 10.2.0 39us 2006-10-04 15:23:12.534 <br /> 11.0 CTL 23 03 04 00 02 00 00 00 SET FEATURE 12.1.0 39ms 2006-10-04 15:23:12.574 <br /> 11.0 CTL a3 00 00 00 02 00 04 00 GET STATUS 13.1.0 26ms 2006-10-04 15:23:12.600 <br /> 11.0 DI 03 01 10 00 .... 13.2.0 31us 2006-10-04 15:23:12.600 <br /> 11.0 CTL 23 01 14 00 02 00 00 00 CLEAR FEATURE 14.1.0 6us 2006-10-04 15:23:12.600 <br /> 11.0 CTL 80 06 00 03 00 00 ff 00 GET DESCRIPTOR 15.1.0 128ms 2006-10-04 15:23:12.728 <br /> 11.0 DI 04 03 09 04 .... 15.2.0 26ms 2006-10-04 15:23:12.755 <br /> 11.0 CTL 80 06 03 03 09 04 ff 00 GET DESCRIPTOR 16.1.0 38us 2006-10-04 15:23:12.755 <br /> 11.0 DI 16 03 32 00 30 00 30 00 37 00 2d 00 30 00 33 00 ..2.0.0.7.-.0.3. 16.2.0 36ms 2006-10-04 15:23:12.792 <br /> 2d 00 32 00 33 00 -.2.3. 16.2.16 <br /> 11.0 CTL 80 06 00 02 00 00 ff 00 GET DESCRIPTOR 17.1.0 35us 2006-10-04 15:23:12.792 <br /> 11.0 DI 0a 02 2e 00 01 01 00 a0 32 00 09 04 00 00 02 03 ........2....... 17.2.0 40ms 2006-10-04 15:23:12.833 <br /> 01 01 00 00 0a 21 01 00 00 01 22 00 3f 00 08 05 .....!....".?... 17.2.16 <br /> 11.0 CTL 23 01 01 00 02 00 00 00 CLEAR FEATURE 18.1.0 344ms 2006-10-04 15:23:13.177 <br /><br />修改的配置,接口,端点等描述符结构体<br />DEVICE_DESCRIPTOR_STRUCT device_descriptor= //设备描述符<br />{<br /> sizeof(DEVICE_DESCRIPTOR_STRUCT), //设备描述符的字节数大小<br /> DEVICE_DESCRIPTOR, //设备描述符类型编号<br /> 0x0001, //0x0110, //0x1001, //USB版本号<br /> 0x00, //USB分配的设备类代码<br /> 0x00, //USB分配的子类代码<br /> 0x00, //USB分配的设备协议代码<br /> 0x10, //端点0的最大包大小<br /> 0x8304, //0x3412, //厂商编号VID,这里只是作为测试用,请使用自己的VID<br /> 0x0100, //0x7856, //产品编号PID,这里只是作为测试用,请使用自己的PID<br /> 0x0401, //0x0100, //设备出厂编号<br /> 0x01, //设备厂商字符串的索引<br /> 0x02, //描述产品字符串的索引<br /> 0x03, //描述设备序列号字符串的索引<br /> 0x01 //可能的配置数量<br />};<br /><br />//定义配置,接口,端点等描述符结构体,因为它们是随配置描述符一起返回的<br />typedef struct _CON_INT_ENDP_DESCRIPTOR_STRUCT<br />{<br /> CONFIGURATION_DESCRIPTOR_STRUCT configuration_descriptor;<br /> INTERFACE_DESCRIPTOR_STRUCT interface_descriptor;<br /> HID_DESCRIPTOR_STRUCT hid_descriptor;<br /> ENDPOINT_DESCRIPTOR_STRUCT endpoint_descriptor[ENDPOINT_NUMBER];<br />}CON_INT_ENDP_DESCRIPTOR_STRUCT;<br /><br />CON_INT_ENDP_DESCRIPTOR_STRUCT con_int_endp_descriptor=<br />{<br />//configuration_descriptor //配置描述符<br />{<br /> sizeof(CONFIGURATION_DESCRIPTOR_STRUCT), //配置描述符的字节数大小<br /> CONFIGURATION_DESCRIPTOR, //配置描述符类型编号<br /> sizeof(CON_INT_ENDP_DESCRIPTOR_STRUCT), //SWAP16(sizeof(CON_INT_ENDP_DESCRIPTOR_STRUCT)),<br /> 0x01, //只包含一个接口<br /> 0x01, //该配置的编号<br /> 0x00, //iConfiguration字段<br /> 0xA0, //采用总线供电,支持远程唤醒<br /> 0x32, //0xC8 //从总线获取最大电流400mA<br />},<br />//interface_descritor //接口描述符<br />{<br /> sizeof(INTERFACE_DESCRIPTOR_STRUCT), //接口描述符的字节数大小<br /> INTERFACE_DESCRIPTOR, //接口描述符类型编号<br /> 0x00, //接口编号为0<br /> 0x00, //该接口描述符的编号<br /> ENDPOINT_NUMBER, //非0端点数量为2,只使用端点主端点输入和输出<br /> 0x03, //人机接口设备(HID)类<br /> 0x01, //使用的子类:支持BIOS根启动Boot的子类<br /> 0x01, //使用的协议:键盘<br /> 0x00 //接口描述符字符串索引<br />},<br />//hid_descriptor<br />{<br /> sizeof(HID_DESCRIPTOR_STRUCT), //HID描述符的字节数大小<br /> HID_DESCRIPTOR, //HID描述符类型编号<br /> 0x0001, //0x0110, //0x1001, //HID类协议版本号,为1.1<br /> 0x00, //0x21, //固件的国家地区代号,0x21为美国<br /> NUM_SUB_DESCRIPTORS, //下级描述符的数量<br /> {<br /> {<br /> REPORT_DESCRIPTOR, //下级描述符为报告描述符<br /> sizeof(KeyBoardReportDescriptor) //SWAP16(sizeof(KeyBoardReportDescriptor)) //下级描述符的长度<br /> }<br /> },<br />},<br />//endpoint_descriptor[]<br />{<br /> { //主端点输入描述<br /> sizeof(ENDPOINT_DESCRIPTOR_STRUCT), //端点描述符的字节数大小<br /> ENDPOINT_DESCRIPTOR, //端点描述符类型编号<br /> MAIN_POINT_IN, //端点号,主输入端点<br /> ENDPOINT_TYPE_INTERRUPT, //使用的传输类型:中断传输<br /> 0x0040, //0x4000, //该端点支持的最大包尺寸,64字节<br /> 0x20, //0x0A //中断扫描时间:设置为10ms<br /> },<br /> <br /> { //主端点输出描述<br /> sizeof(ENDPOINT_DESCRIPTOR_STRUCT), //端点描述符的字节数大小<br /> ENDPOINT_DESCRIPTOR, //端点描述符类型编号<br /> MAIN_POINT_OUT, //端点号,主输出端点<br /> ENDPOINT_TYPE_INTERRUPT, //使用的传输类型:中断传输<br /> 0x0040, //0x4000, //该端点支持的最大包尺寸,64字节<br /> 0x20,//0x0A //中断扫描时间:设置为10ms<br /> }<br />}<br />};<br />
