我现在用ISP1581开发USB2.0,固件程序参考了别人的代码,驱动用的是ISP1581通用驱动程序,现在用VC++开发一个应用程序,实现了中断及批量传输,但是都是在全速模式低下(FullSpeed),固件程序中全速到高速的转换程序己经有了,现在我不懂在应用程序中哪个命令是要进行高速传输的,我的头文件中只有以下的命令,望高手赐教,或给个建议,谢谢!<br /><br /><br />#define XXGDRV_IOCTL_DRV_VERSION CTL_CODE(FILE_DEVICE_UNKNOWN, 0x800, METHOD_BUFFERED, FILE_ANY_ACCESS)<br />#define XXGDRV_IOCTL_DEV_VERSION CTL_CODE(FILE_DEVICE_UNKNOWN, 0x801, METHOD_BUFFERED, FILE_ANY_ACCESS)<br />#define XXGDRV_IOCTL_SYS_INIT CTL_CODE(FILE_DEVICE_UNKNOWN, 0x802, METHOD_BUFFERED, FILE_ANY_ACCESS)<br />#define XXGDRV_IOCTL_DEV_INIT CTL_CODE(FILE_DEVICE_UNKNOWN, 0x803, METHOD_BUFFERED, FILE_ANY_ACCESS)<br />#define XXGDRV_IOCTL_READ_DATA CTL_CODE(FILE_DEVICE_UNKNOWN, 0x804, METHOD_BUFFERED, FILE_ANY_ACCESS)<br />#define XXGDRV_IOCTL_WRITE_DATA CTL_CODE(FILE_DEVICE_UNKNOWN, 0x805, METHOD_BUFFERED, FILE_ANY_ACCESS)<br />#define XXGDRV_IOCTL_SET_CMD CTL_CODE(FILE_DEVICE_UNKNOWN, 0x806, METHOD_BUFFERED, FILE_ANY_ACCESS)<br />#define XXGDRV_IOCTL_GET_CMD CTL_CODE(FILE_DEVICE_UNKNOWN, 0x807, METHOD_BUFFERED, FILE_ANY_ACCESS)<br />#define XXGDRV_IOCTL_CONTROL CTL_CODE(FILE_DEVICE_UNKNOWN, 0x808, METHOD_BUFFERED, FILE_ANY_ACCESS)<br />#define XXGDRV_IOCTL_ENABLE_ISO_MODE CTL_CODE(FILE_DEVICE_UNKNOWN, 0x809, METHOD_BUFFERED, FILE_ANY_ACCESS)<br />#define XXGDRV_IOCTL_READ_WRITE_REGISTER CTL_CODE(FILE_DEVICE_UNKNOWN, 0x80a, METHOD_BUFFERED, FILE_ANY_ACCESS)<br /><br /><br />HANDLE CUSBApp::OpenDevice(DWORD dwInstance, PDWORD pdwError)<br />{<br /> HANDLE hDev;<br /> // Class GUID used to open device<br /> //<br /> GUID ClassGuid = XXGDrvDevice_CLASS_GUID;<br /> CDeviceInterfaceClass DevClass(&ClassGuid, pdwError);<br /> <br /> if(*pdwError != ERROR_SUCCESS)<br /> return INVALID_HANDLE_VALUE;<br /> <br /> CDeviceInterface DevInterface(&DevClass, dwInstance, pdwError);<br /> <br /> if(*pdwError != ERROR_SUCCESS)<br /> return INVALID_HANDLE_VALUE;<br /> <br /> hDev = CreateFile(<br /> DevInterface.DevicePath(),<br /> GENERIC_READ | GENERIC_WRITE,<br /> FILE_SHARE_READ | FILE_SHARE_WRITE,<br /> NULL,<br /> OPEN_EXISTING,<br /> FILE_ATTRIBUTE_NORMAL,<br /> NULL<br /> );<br /> <br /> //if(lpszDevicePath)<br /> // _tcscpy(lpszDevicePath, DevInterface.DevicePath());<br /> <br /> if(hDev == INVALID_HANDLE_VALUE)<br /> *pdwError = GetLastError();<br /> <br /> return hDev;<br />} |
