用BusHound、串口分别获取的USB数据怎么不一致呢?
4789|2
cnchip|  楼主 | 2009-3-12 20:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这是BusHound拦截的:
Device  Phase  Data                                                Description       Cmd.Phase.Ofs(rep)  Time
  24.0  CTL    80 06 00 01  00 00 12 00                            GET DESCRIPTOR           1.1.0        11:45:50.728
  24.0  DI     12 01 10 01  00 00 00 20  05 82 00 11  00 00 00 00  ....... ........         1.2.0        11:45:50.777
               00 01                                               ..                       1.2.16
  24.0  CTL    80 06 00 02  00 00 09 00                            GET DESCRIPTOR           2.1.0        11:45:50.777
  24.0  DI     09 02 20 00  01 01 00 80  fa                        .. ......                2.2.0        11:45:50.824
  24.0  CTL    80 06 00 02  00 00 20 00                            GET DESCRIPTOR           3.1.0        11:45:50.824
  24.0  DI     09 02 20 00  01 01 00 80  fa 09 04 00  00 02 08 06  .. .............         3.2.0        11:45:50.871
               50 00 07 05  81 02 40 00  00 07 05 02  02 40 00 00  P.....@......@..         3.2.16
  24.0  CTL    00 09 01 00  00 00 00 00                            SET CONFIG               4.1.0        11:45:50.871
  24.0  CTL    01 0b 00 00  00 00 00 00                            SET INTERFACE            5.1.0        11:45:50.951
  24.0  CTL    a1 fe 00 00  00 00 01 00                            GET MAX LUN              6.1.0(3)     11:45:50.986
这是串口获取的endpoint 0的数据:
Ep0-->>
DT[0]-->>DT[8]:80 06 00 01 00 00 40 00 00这段数据为何在BusHound中找不到?
Compulete Read DT[?].
Ep0-->>
DT[0]-->>DT[0]:00
Ep0-->>
DT[0]-->>DT[8]:00 05 02 00 00 00 00 00 00
Ep0-->>
DT[0]-->>DT[8]:80 06 00 01 00 00 12 00 00
Ep0-->>
DT[0]-->>DT[8]:80 06 00 02 00 00 09 00 00
Ep0-->>
DT[0]-->>DT[8]:80 06 00 02 00 00 FF 00 00
Ep0-->>
DT[0]-->>DT[0]:00
Ep0-->>
Ep0-->>
Ep0-->>
DT[0]-->>DT[8]:80 06 00 02 00 00 20 00 00
Ep0-->>
DT[0]-->>DT[8]:00 09 01 00 00 00 00 00 00
Ep0-->>
DT[0]-->>DT[8]:A1 FE 00 00 00 00 01 00 00
Ep0-->>
Ep0-->>
Ep0-->>
DT[0]-->>DT[0]:00
computer00| | 2009-3-12 20:50 | 只看该作者
在win XP下,未设置地址之前的数据是看不到的。
在win2000下可以看到完整的。
cnchip|  楼主 | 2009-3-12 21:44 | 只看该作者
哦,这样,谢谢圈圈啊
刚才也搜到一些你以前的回帖了,再次感谢!
