USB 插座接地讨论
13098|10
 楼主| zhang..yb 发表于 2009-5-7 09:24 | 显示全部楼层 |阅读模式
USB&nbsp;插座是直接接地,还是通过电容接地,或者不接地。<br />哪种最合适?我查了下电脑USB口,发现外壳已接地了,屏蔽线应该单端接地,<br />那么应用板上应该不接地,我的理解对吗?
computer00 发表于 2009-5-7 09:37 | 显示全部楼层
屏蔽线是两端接地的,外壳直接接地。
 楼主| zhang..yb 发表于 2009-5-7 10:07 | 显示全部楼层
两端接地的话,屏蔽层冲当地线了,会影响屏蔽效果
computer00 发表于 2009-5-7 16:30 | 显示全部楼层
数字系统和模拟系统的接地方法是不一样的。
gxq 发表于 2009-5-22 17:00 | 显示全部楼层
下述3种方式都有应用,高速传输时不可悬空。
1)直接接地;<br />2)通过磁珠接地;<br />3)通过高频电容接地;<br /><br />5.2.USB&nbsp;Cable&nbsp;Shielding<br />Standard&nbsp;USB&nbsp;cables&nbsp;always&nbsp;connect&nbsp;both&nbsp;ends&nbsp;of&nbsp;the&nbsp;cable&nbsp;shield&nbsp;to&nbsp;the&nbsp;shell&nbsp;of&nbsp;the&nbsp;USB&nbsp;connector.&nbsp;&nbsp;On&nbsp;most&nbsp;systems,&nbsp;this&nbsp;will&nbsp;interconnect&nbsp;the&nbsp;grounds&nbsp;between&nbsp;USB&nbsp;nodes,&nbsp;turning&nbsp;the&nbsp;shield&nbsp;into&nbsp;a&nbsp;current&nbsp;carrying&nbsp;conductor&nbsp;if&nbsp;there&nbsp;is&nbsp;a&nbsp;difference&nbsp;in&nbsp;voltage&nbsp;between&nbsp;the&nbsp;two&nbsp;grounds.&nbsp;&nbsp;If&nbsp;the&nbsp;shield&nbsp;is&nbsp;allowed&nbsp;to&nbsp;pass&nbsp;a&nbsp;significant&nbsp;amount&nbsp;of&nbsp;current,&nbsp;it&nbsp;can&nbsp;radiate&nbsp;noise&nbsp;into&nbsp;the&nbsp;signal&nbsp;wires.&nbsp;<br />Most&nbsp;instrumentation&nbsp;cables&nbsp;are&nbsp;designed&nbsp;so&nbsp;that&nbsp;only&nbsp;one&nbsp;end&nbsp;of&nbsp;the&nbsp;shield&nbsp;is&nbsp;terminated&nbsp;so&nbsp;as&nbsp;to&nbsp;avoid&nbsp;turning&nbsp;the&nbsp;shield&nbsp;wiring&nbsp;into&nbsp;a&nbsp;noise&nbsp;inducing&nbsp;source&nbsp;when&nbsp;it&nbsp;is&nbsp;forced&nbsp;to&nbsp;pass&nbsp;current.&nbsp;&nbsp;Disconnecting&nbsp;one&nbsp;end&nbsp;of&nbsp;the&nbsp;shield&nbsp;wiring&nbsp;can&nbsp;often&nbsp;significantly&nbsp;reduce&nbsp;USB&nbsp;communications&nbsp;problems.<br /><br />
 楼主| zhang..yb 发表于 2009-5-26 13:23 | 显示全部楼层
设备端的外壳接地
Disconnecting&nbsp;one&nbsp;end&nbsp;of&nbsp;the&nbsp;shield&nbsp;wiring&nbsp;can&nbsp;often&nbsp;significantly&nbsp;reduce&nbsp;USB&nbsp;communications&nbsp;problems.<br />断开一端的外壳联接(接地)通常能显著减少USB的通讯问题<br /><br />所以我觉得:在非自供电场合,设备端的外壳接地应取消
cool_coder 发表于 2009-5-26 23:50 | 显示全部楼层
接地确实是个让人头疼的问题
也许解决屏蔽层过电流的问题才是关键
gxq 发表于 2009-5-27 14:01 | 显示全部楼层
几种应用都可以,如果有问题,要从系统区分析选择!
直接接地,应用在日本某消费电子公司的USB2.0产品,通过USB2.0一致性测试及FCC等电磁兼容测试,全球销售。<br />
gxq 发表于 2009-5-27 14:03 | 显示全部楼层
TI design guide
kaiwen21ic 发表于 2009-6-20 21:18 | 显示全部楼层
学习了。
stinby 发表于 2013-10-4 16:25 | 显示全部楼层
有效吗???
