| stm32兼容5V的FT管脚,到底能不能在开漏模式下输出5V,我现把实测上拉到5V时,输出始终只有3.3V,怎么回事?按如下方式初始化。配置成输入时,也只有3.3V。芯片型号STM32F103RCT GPIO_InitStructure.GPIO_Pin=GPIO_Pin_6 |GPIO_Pin_7 | GPIO_Pin_10 | GPIO_Pin_11 | GPIO_Pin_12;
 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;                  //GPIO_Mode_AF_OD;//开漏输出
 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;                 //IO口速度为50MHz
 GPIO_Init(GPIOC, &GPIO_InitStructure);                                           //根据设定参数初始化GPIOC
