[PIC®/AVR®/dsPIC®产品] Programming...PIC烧写器出现错误
2423|5
 楼主| qhtflsw 发表于 2015-10-9 13:43 | 显示全部楼层 |阅读模式
PICkit 3 detected
Connecting to PICkit 3...
Firmware Suite Version...... 01.28.90
Firmware type......................Enhanced Midrange
PICkit 3 Connected.
Target Device ID (00000000) does not match expected Device
ID (00002380).
烧写器之前还能用,如今提示这个错误。感觉烧写器坏了。能修吗?
Programming...
The following memory regions failed to program correctly:
Program Memory
Address: 00000000 Expected Value: 00003181 Received Value: 00000000
Programming failed
arghj 发表于 2015-10-9 13:53 | 显示全部楼层
看看是否供电正常?
StevenLau2008 发表于 2015-10-13 12:43 | 显示全部楼层
QQ:359920019
TEL:13148736025 刘R
millenniumm 发表于 2015-10-13 22:55 | 显示全部楼层
但有可能是线接触不良,我用的kit3每次要用手扶着线接头才好用
 楼主| qhtflsw 发表于 2016-1-31 14:37 | 显示全部楼层
烧写器坏了。懒得修了
GeekyGeek 发表于 2016-2-1 21:44 | 显示全部楼层
烧写器坏了。懒得修了
不修就寄给我吧,我感觉不像是烧写器坏
