[i.MX]
I.MX535烧写内核问题(附带日志)求解答
1145|4
nathanyjy|  楼主 | 2015-10-11 09:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
I.MX535烧写内核时,到jumping to os image时后面无法运行。求解答,附带烧写日志。
1 - Panel A Start processing MX53LOCO-SD <LIST/>.
Panel A Start <CMD/> type="boot" body="BootStrap" file="u-boot-mx53-loco.bin" timeout="10" onError="" text="Read from DDR script from U-Boot to init DDR Memory.".
1 - Panel A Finished <CMD/> type="boot" body="BootStrap" file="u-boot-mx53-loco.bin" timeout="10" onError="" text="Read from DDR script from U-Boot to init DDR Memory." SUCCESS code=0x0.
Panel A Start <CMD/> type="load" body="" file="uImage" timeout="10" onError="" text="Doing Kernel.".
1 - Panel A Finished <CMD/> type="load" body="" file="uImage" timeout="10" onError="" text="Doing Kernel." SUCCESS code=0x0.
Panel A Start <CMD/> type="load" body="" file="initramfs.cpio.gz.uboot" timeout="10" onError="" text="Doing Initramfs.".
1 - Panel A Finished <CMD/> type="load" body="" file="initramfs.cpio.gz.uboot" timeout="10" onError="" text="Doing Initramfs." SUCCESS code=0x0.
Panel A Start <CMD/> type="jump" body="" file="" timeout="10" onError="" text=" Jumping to OS image. ".
1 - Panel A Finished <CMD/> type="jump" body="" file="" timeout="10" onError="" text=" Jumping to OS image. " SUCCESS code=0x0.
Panel A Start <CMD/> type="find" body="Updater" file="" timeout="180" onError="" text="".
Panel A UtpUpdate Event: DeviceRemoval Msg: (null) DevState: Disconnected OpState: WAITING_FOR_DEVICE
Panel A UtpUpdate Event: VolumeArrival Msg: (null) DevState: Updater OpState: WAITING_FOR_DEVICE
1 - Panel A Finished <CMD/> type="find" body="Updater" file="" timeout="180" onError="" text="" SUCCESS code=0x0.
Panel A Start <CMD/> type="push" body="mknod block,mmcblk0,/dev/mmcblk0,block" file="" timeout="10" onError="" text="".
1 - Panel A Finished <CMD/> type="push" body="mknod block,mmcblk0,/dev/mmcblk0,block" file="" timeout="10" onError="" text="" FAIL code=0xffffffea.
Panel A: Command is not supported by device.,failed to run command: type="push" body="mknod block,mmcblk0,/dev/mmcblk0,block" file="" timeout="10" onError="" text=""
2 - Panel A Finished processing MX53LOCO-SD <LIST/> : FAIL code=-22.
Panel A: Reason is unknown,
FSL_TICS_Rita| | 2015-10-14 17:26 | 只看该作者
楼主你好,请问你这里烧写的是自己编译的images吗?
FSL_TICS_Rita| | 2015-10-14 17:27 | 只看该作者
你这里是使用的哪个版本的mfgtool?还有你这里使用的板子是你自己的设计的吗,DDR部分和开发板是否一样?
mini1986| | 2015-10-19 09:38 | 只看该作者
FSL_TICS_Rita 发表于 2015-10-14 17:27
你这里是使用的哪个版本的mfgtool?还有你这里使用的板子是你自己的设计的吗,DDR部分和开发板是否一样? ...
好多人问这种问题呢......出个详细的使用说明和问题总结吧,哈哈......
nathanyjy|  楼主 | 2015-10-20 13:32 | 只看该作者
大家出现问题的原因都不怎么一样~~苦逼了
