[i.MX] 新人贴:imx6sl 开机启动初始化信息 界面
5557|2
 楼主| ljjvip 发表于 2015-10-15 08:46 | 显示全部楼层 |阅读模式
手上imx6sl 的一个项目在ODM 工厂成功打样后开机~~ 开贴记录
通电连上 串口显示软件putty后的初始化界面:
Starting kernel ...
Booting Linux on physical CPU 0x0
Initializing cgroup subsys cpu
Initializing cgroup subsys cpuacct
Linux version 3.10.53+1.0.0#78 (ubuntu@tools-tprd1e01-androidbuild-2) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Thu Sep 17 00:45:46 UTC 2015
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Freescale i.MX6 SoloLite (Device Tree), model: SUR-1000
cma: CMA: reserved 256 MiB at 8a000000
Memory policy: ECC disabled, Data cache writealloc
PERCPU: Embedded 8 pages/cpu @81332000 s9728 r8192 d14848 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 129792
Kernel command line: console=ttymxc0,115200 init=/init consoleblank=0 video=mxc_elcdif_fb:bpp=32 mmcboot=1 bluetooth androidboot.console=ttymxc0 androidboot.hardware=freescale androidboot.serialno=sur1000-default-sn androidboot.partno=068-0471-20 androidboot.btaddr=DE:AD:BE:EF:CA:FE androidboot.basebtaddr=11:22:33:44:55:66 androidboot.sku=SAV-CRU-0100-0010 androidboot.mmcboot=1 androidboot.mmcsys=5 androidboot.mfg_test=0 androidboot.mode=normal androidboot.low_battery=0 androidboot.uboot_ver=1.0.1
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 447MB 64MB = 511MB total
Memory: 239960k/239960k available, 284328k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xa0800000 - 0xff000000   (1512 MB)
    lowmem  : 0x80000000 - 0xa0000000   ( 512 MB)
    pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
    modules : 0x7f000000 - 0x7fe00000   (  14 MB)
      .text : 0x80008000 - 0x80d7adb8   (13772 kB)
      .init : 0x80d7b000 - 0x80e16600   ( 622 kB)
      .data : 0x80e18000 - 0x80e90340   ( 481 kB)
       .bss : 0x80e90340 - 0x80f21eb0   ( 583 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Preemptible hierarchical RCU implementation.
        RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
NR_IRQS:16 nr_irqs:16 16
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x32030000, Cache size: 262144 B
sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
Console: colour dummy device 80x30
Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
pid_max: default: 32768 minimum: 301
Security Framework initialized
SELinux:  Initializing.
Mount-cache hash table entries: 512
device-tree: Duplicate name in [url=]/soc/aips-bus@02000000/lcdif@020f8000[/url], renamed to "display#1"
Initializing cgroup subsys debug
Initializing cgroup subsys freezer
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x80716e80 - 0x80716ed8
Brought up 1 CPUs
SMP: Total of 1 processors activated (1581.05 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
pinctrl core: initialized pinctrl subsystem
regulator-dummy: no parameters
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
Use WDOG1 as reset source
syscon 20c8000.anatop: regmap [mem 0x020c8000-0x020c8fff] registered
ldo2p5-dummy: no parameters
Bus freq driver module loaded
bt power gpio is:14
mxc_bt_rfkill driver success loaded
rfkill: BT RF going to : on
mxc_bt_rfkill_reset
console [pstore-1] enabled
ramoops: attached 0x100000@0x9bf00000, ecc: 0/0
mxc_ramoops device success loaded
futex hash table entries: 256 (order: 2, 16384 bytes)
audit: initializing netlink socket (disabled)
type=2000 audit(0.250:1): initialized
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
NTFS driver 2.1.30 [Flags: R/W DEBUG].
fuse init (API version 7.22)
msgmni has been set to 981
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
MIPI DSI driver module loaded
mxsfb 20f8000.lcdif: failed to find mxc display driver
Console: switching to colour frame buffer device 80x30
mxsfb 20f8000.lcdif: initialized
imx-sdma 20ec000.sdma: loaded firmware 1.1
imx-sdma 20ec000.sdma: initialized
pfuze100-regulator 0-0008: Full lay: 2, Metal lay: 1
pfuze100-regulator 0-0008: FAB: 0, FIN: 0
pfuze100-regulator 0-0008: pfuze200 found.
Serial: IMX driver
2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
console [ttymxc0] enabled
2024000.serial: ttymxc1 at MMIO 0x2024000 (irq = 59) is a IMX
serial: Freescale lpuart driver
imx sema4 driver is registered.
[drm] Initialized drm 1.1.0 20060810
[drm] Initialized vivante 1.0.0 20120216 on minor 0
brd: module loaded
loop: module loaded
lis2dh_acc accelerometer driver: init
lis2dh_acc 1-0019: probe start.
lis2dh_acc 1-0019: using default plaform_data
lis2dh_acc: lis2dh_acc_probe has set irq1 to irq: 161, mapped on gpio:1
lis2dh_acc: lis2dh_acc_probe has set irq2 to irq: 162, mapped on gpio:2
lis2dh_acc: hw init start
lis2dh_acc: hw init done
lis2dh_acc 1-0019: lis2dh_acc: probed
i2c-core: driver [lis2dh_acc] using legacy suspend method
i2c-core: driver [lis2dh_acc] using legacy resume method
##### lam030x548b driver!!!
spi_imx 200c000.ecspi: probed
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
PPP generic driver version 2.4.2
PPP BSD Compression module registered
PPP Deflate Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
usbcore: registered new interface driver asix
usbcore: registered new interface driver ax88179_178a
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
usbcore: registered new interface driver cdc_ncm
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver option
usbserial: USB Serial support registered for GSM modem (1-port)
ci_hdrc ci_hdrc.1: EHCI Host Controller
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 3.10.53+1.0.0#78 ehci_hcd
usb usb1: SerialNumber: ci_hdrc.1
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mousedev: PS/2 mouse device common for all mice
input: adp5588 as /devices/soc0/soc.2/2100000.aips-bus/21a4000.i2c/i2c-1/1-0034/input/input0
adp5588-keys 1-0034: Rev.4 keypad, irq 160
Error: Driver 'adp5588-keys' is already registered, aborting...
usbcore: registered new interface driver xpad
usbcore: registered new interface driver usb_acecad
usbcore: registered new interface driver aiptek
usbcore: registered new interface driver gtco
usbcore: registered new interface driver hanwang
usbcore: registered new interface driver kbtab
usbcore: registered new interface driver wacom
atmel_mxt_ts 0-004a: Family: 164 Variant: 22 Firmware V2.0.AA Objects: 39
atmel_mxt_ts 0-004a: T100 Touchscreen size X639Y479
atmel_mxt_ts 0-004a: Invalid object type T107
input: atmel_mxt_ts T100 as /devices/soc0/soc.2/2100000.aips-bus/21a0000.i2c/i2c-0/0-004a/input/input1
i2c-core: driver [isl29023] using legacy suspend method
i2c-core: driver [isl29023] using legacy resume method
snvs_rtc 20cc034.snvs-rtc-lp: rtc core: registered 20cc034.snvs-rtc-lp as rtc0
i2c /dev entries driver
usbcore: registered new interface driver uvcvideo
USB Video Class driver (1.1.1)
gspca_main: v2.14.0 registered
bq27x00_battery_probe
bq27742 1-0055: Gas Guage fw version is 0x0103
bq27742 1-0055: support ver. 1.2.0 enabled
[bq24296_charger_init] init process start
bq24296_driver_probe has set to irq: 185, mapped on gpio:25
input: bq24296 as /devices/soc0/soc.2/2100000.aips-bus/21a4000.i2c/i2c-1/1-006b/input/input2
[bq24296_init] Success to register bq24296 i2c driver.
******** bq24296_user_space_probe!! ********
imx2-wdt 20bc000.wdog: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
Bluetooth: Virtual HCI driver ver 1.3
Bluetooth: HCI UART driver ver 2.2
Bluetooth: HCI H4 protocol initialized
Bluetooth: HCI BCSP protocol initialized
Bluetooth: HCILL protocol initialized
Bluetooth: HCIATH3K protocol initialized
usbcore: registered new interface driver btusb
usbcore: registered new interface driver ath3k
cpuidle: using governor ladder
cpuidle: using governor menu
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: no vqmmc regulator found
mmc0: no vmmc regulator found
mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using DMA
galcore: clk_get gpu3d_clk failed, disable 3d!
Galcore version 5.0.11.25762
mmc0: BKOPS_EN bit is not set
mmc0: new high speed DDR MMC card at address 0001
mmcblk0: mmc0:0001 SEM08G 7.28 GiB
mmcblk0boot0: mmc0:0001 SEM08G partition 1 2.00 MiB
mmcblk0boot1: mmc0:0001 SEM08G partition 2 2.00 MiB
mmcblk0rpmb: mmc0:0001 SEM08G partition 3 2.00 MiB
mmcblk0: p1 p2 p3 < p5 p6 p7 p8 p9 p10 > p4
mmcblk0boot1: unknown partition table
mmcblk0boot0: unknown partition table
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
ashmem: initialized
logger: created 256K log 'log_main'
logger: created 256K log 'log_events'
logger: created 256K log 'log_radio'
logger: created 256K log 'log_system'
usbcore: registered new interface driver snd-usb-audio
SAVANT imx_adc3x01_probe 00:44:12
imx-adc3x01 sound.25:  adc3101 <-> 202c000.ssi mapping ok
imx-spdif sound-spdif.26:  dit-hifi <-> 2004000.spdif mapping ok
NET: Registered protocol family 26
u32 classifier
    Actions configured
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (7853 buckets, 31412 max)
ctnetlink v0.93: registering with nfnetlink.
NF_TPROXY: Transparent proxy support initialized, version 4.1.0
NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
xt_time: kernel timezone is -0000
ip_tables: (C) 2000-2006 Netfilter Core Team
arp_tables: (C) 2002 David S. Miller
TCP: cubic registered
Initializing XFRM netlink socket
NET: Registered protocol family 10
mip6: Mobile IPv6
ip6_tables: (C) 2000-2006 Netfilter Core Team
NET: Registered protocol family 17
NET: Registered protocol family 15
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: BNEP socket layer initialized
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
8021q: 802.1Q VLAN Support v1.8
Key type dns_resolver registered
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
VGEN1: disabling
SWBST: disabling
usb_otg1_vbus: disabling
regulator-dummy: disabling
imx mcc test is registered.
file system registered
android_usb gadget: Mass Storage Function, version: 2009/09/11
android_usb gadget: Number of LUNs=1
lun0: LUN: removable file: (no medium)
android_usb gadget: android_usb ready
snvs_rtc 20cc034.snvs-rtc-lp: setting system clock to 1970-01-02 00:04:23 UTC (86663)
ALSA device list:
  #0: adc3x01-audio
  #1: imx-spdif
Freeing unused kernel memory: 620K (80d7b000 - 80e16000)
SELinux:  Permission attach_queue in class tun_socket not defined in policy.
SELinux: the above unknown classes and permissions will be denied
type=1403 audit(86663.660:2): policy loaded auid=4294967295 ses=4294967295
SELinux: Loaded policy from /sepolicy
type=1404 audit(86663.670:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
init: /init.freescale.rc: 94: invalid command 'echo'
init: /init.freescale.rc: 141: invalid command 'touch'
init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
rfkill: BT RF going to : off
mxc_bt_rfkill
type=1400 audit(86666.170:4): avc:  denied  { entrypoint } for  pid=111 comm="init" path="/sbin/healthd" dev="rootfs" ino=238 scontext=u:r:healthd:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=1
init: cannot find '/system/bin/drmserver', disabling 'drm'
init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
init: cannot find '/system/bin/keystore', disabling 'keystore'
root@savant_sur1000_6sl:/ # init: cannot find '/system/bin/rild', disabling 'ril-daemon'
init: using deprecated syntax for specifying property 'ro.serialno', use ${name} instead
init: using deprecated syntax for specifying property 'ro.product.manufacturer', use ${name} instead
init: using deprecated syntax for specifying property 'ro.product.model', use ${name} instead
init: property 'sys.powerctl' doesn't exist while expanding '${sys.powerctl}'
init: powerctl: cannot expand '${sys.powerctl}'
init: property 'sys.sysctl.extra_free_kbytes' doesn't exist while expanding '${sys.sysctl.extra_free_kbytes}'
init: cannot expand '${sys.sysctl.extra_free_kbytes}' while writing to '/proc/sys/vm/extra_free_kbytes'
android_usb: already disabled
read descriptors
read strings
mtp_bind_config
warning: `zygote' uses 32-bit capabilities (legacy support in use)
request_suspend_state: wakeup (3->0) at 15624727501 (1970-01-02 00:04:34.687100793 UTC)
lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
lowmemorykiller: oom_adj 0 => oom_score_adj 0
lowmemorykiller: oom_adj 1 => oom_score_adj 58
lowmemorykiller: oom_adj 2 => oom_score_adj 117
lowmemorykiller: oom_adj 3 => oom_score_adj 176
lowmemorykiller: oom_adj 9 => oom_score_adj 529
lowmemorykiller: oom_adj 15 => oom_score_adj 1000
acc_open
acc_release
init: no such service 'fuse_extsd'
type=1400 audit(86676.300:5): avc:  denied  { getattr } for  pid=475 comm="zygote" path="socket:[2431]" dev="sockfs" ino=2431 scontext=u:r:untrusted_app:s0 tcontext=u:r:zygote:s0 tclass=unix_stream_socket permissive=1
type=1400 audit(86676.350:6): avc:  denied  { getopt } for  pid=475 comm="zygote" path="/dev/socket/zygote" scontext=u:r:untrusted_app:s0 tcontext=u:r:zygote:s0 tclass=unix_stream_socket permissive=1
type=1400 audit(86677.300:7): avc:  denied  { read write } for  pid=475 comm="ant.voiceremote" name="galcore" dev="tmpfs" ino=1682 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
type=1400 audit(86677.320:8): avc:  denied  { open } for  pid=475 comm="ant.voiceremote" path="/dev/galcore" dev="tmpfs" ino=1682 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
type=1400 audit(86677.350:9): avc:  denied  { ioctl } for  pid=475 comm="ant.voiceremote" path="/dev/galcore" dev="tmpfs" ino=1682 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
mxc_bt_rfkill
mxc_bt_rfkill_reset
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 2
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: EHCI Host Controller
usb usb2: Manufacturer: Linux 3.10.53+1.0.0#78 ehci_hcd
usb usb2: SerialNumber: ci_hdrc.0
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
ci_hdrc ci_hdrc.0: remove, state 4
usb usb2: USB disconnect, device number 1
ci_hdrc ci_hdrc.0: USB bus 2 deregistered
ci_hdrc ci_hdrc.0: remove, state 1
dProduct=0002
0x11
root@savant_sur1000_6sl:/ # request_suspend_state: sleep (0->3) at 78974455842 (1970-01-02 00:05:38.036829217 UTC)
active wake lock PowerManagerService.Display
FSL_TICS_Rita 发表于 2015-10-15 11:28 | 显示全部楼层
恭喜楼主,板子成功启动:victory:
mini1986 发表于 2015-10-19 10:03 | 显示全部楼层
为啥别人的板子,这么顺利就OK了......
