[i.MX] imx6q Tw6865设备号怎么改?
1080|1
 楼主| mason1994 发表于 2015-10-16 16:47 | 显示全部楼层 |阅读模式
貌似是tw6865采集卡的主芯片坏了,很烫,并且pcie一直link failed,就跟没连接采集卡一样,但是没有连接采集卡的时候依旧载入了tw68的驱动,并且映射了video16-20,这是怎么回事?还有video16-20能不能改成video0-4?怎么改?以下是启动log节选
PM driver module loaded
iMX6 PCIe PCIe RC mode imx_pcie_pltfm_probe entering.
PCIE: imx_pcie_pltfm_probe start link up.
link up failed, DB_R0:0x00427400, DB_R1:0x08200000!
IMX PCIe port: link down!
IMX usb wakeup probe
the wakeup pdata is 0xbfd29840
Linux video capture interface: v2.00
TW6868_: v4l2 driver version 2.0.1 loaded
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video18
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video19
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video20
mag3110 2-000e: check mag3110 chip ID
mag3110 2-000e: read chip ID 0xfffffffb is not equal to 0xc4!
mini1986 发表于 2015-10-19 10:30 | 显示全部楼层
没搞过,帮你顶起来,期待后续有大神帮你解决......
