[技术问题解答] IMX6DL android 5.0 device tree LCD ENABLE GPIO
1666|3
 楼主| mobz 发表于 2015-10-22 20:13 | 显示全部楼层 |阅读模式
如何在DT里配置DI0_PIN15这个管脚为LCD使能脚?我的配置如下,可是行不通
FB里添加GPIO:
    mxcfb1: fb@0 {
        compatible = "fsl,mxc_sdc_fb";
        disp_dev = "ldb";
        interface_pix_fmt = "RGB24";
        mode_str ="1280x800@60";
        default_bpp = <18>;
        int_clk = <0>;
        late_init = <0>;
        pinctrl-names = "default";
        my_lcd_pin = <&pinctrl_mylcd>;
        status = "ok";
管脚配置:
    mylcdmux {
        pinctrl_mylcd: mylcd {
            fsl,pins = <
                MX6QDL_PAD_DI0_PIN15__LCD_ENABLE 0x1b0b1
驱动中使用:(主要是在这里调用的时候有问题
    plat_data->gpio_int = of_get_named_gpio(np, "my_lcd_pin", 0);
    if (plat_data->gpio_int == -EPROBE_DEFER)
        return -1;
    if (!gpio_is_valid(plat_data->gpio_int)) {
        printk("ERROR, emmmxxoo--->failed to get interrupt gpio\n");
        return 1;
    lcd_enable = gpio_get_value(plat_data->gpio_int);
    printk("shady---->lcd_eanble = %d\n", lcd_enable);
错误日志:
[    0.393015] /fb@0: could not get #gpio-cells for /soc/aips-bus@02000000/iomuxc@020e0000/mylcdmux/mylcd
[    0.393024] ERROR, emmmxxoo--->failed to get interrupt gpio
芙蓉洞 发表于 2015-10-22 20:27 | 显示全部楼层
我也不是很清楚,帮楼主顶一下
 楼主| mobz 发表于 2015-10-22 20:44 | 显示全部楼层
我也不是很清楚,帮楼主顶一下
你真是好人
kris_fei 发表于 2016-3-24 15:44 | 显示全部楼层
http://blog.csdn.net/kris_fei/article/details/50970023
