菜鸟求助
2250|4
rxb00000|  楼主 | 2008-9-19 16:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ce, se, ST, ic, ev
小弟刚刚接触psoc,我按照说明下载例程到first touch和 CY29466 在下载的时候,总是出现,我应该怎么解决啊?
Programming Failed at 16:00:39
                     Verify Failed
                     Verify starting
                     Programming succeeded
                     Programming starting
                     Erase succeeded
                     Silicon: 38, Family/Die: 15, Major Rev: A
Programming Requested at 15:59:56
Successful port connection for FirstTouch/1 at 15:59:52
Active HEX file set to C:Documents and Settings xbMy Documentssidersideroutputsider.hex at 15:59:51
Device set to CY8C21434-24LFXI at 15:59:51    8192 FLASH bytes
Device Family set to 21x34 at 15:59:51
Open at 15:59:51    FirstTouch Programmer Version 1.80
Device set to CY8C21434-24LFXI at 15:59:49
Device Family set to 21x34 at 15:59:49
牛刀小试| | 2008-9-22 14:14 | 只看该作者
回楼主
1.first touch里用的是21434,不是29466。
2.您换一个PSoC programmer版本就好了
rxb00000|  楼主 | 2008-9-28 19:55 | 只看该作者
xie
谢谢 ,问题解决了
xuzhi1123| | 2009-10-23 16:27 | 只看该作者
怎么解决的?
谢谢
