[嵌入式linux] tslib编译出问题
2376|3
 楼主| Crazyoncemore84 发表于 2015-10-26 20:34 | 显示全部楼层 |阅读模式
我在编译tslib的时候遇到了问题,不知道怎么解决。
linux@ubuntu:~/qt-arm/tslib$ ./autogen.sh
libtoolize: putting auxiliary files in `.'.
libtoolize: copying file `./ltmain.sh'
libtoolize: putting macros in `m4/internal'.
libtoolize: copying file `m4/internal/libtool.m4'
libtoolize: copying file `m4/internal/ltoptions.m4'
libtoolize: copying file `m4/internal/ltsugar.m4'
libtoolize: copying file `m4/internal/ltversion.m4'
libtoolize: copying file `m4/internal/lt~obsolete.m4'
libtoolize: Consider adding `AC_CONFIG_MACRO_DIR([m4])' to configure.ac and
libtoolize: rerunning libtoolize, to keep the correct libtool macros in-tree.
plugins/Makefile.am:14: warning: 'INCLUDES' is the old name for 'AM_CPPFLAGS' (or '*_CPPFLAGS')
tests/Makefile.am:13: warning: 'INCLUDES' is the old name for 'AM_CPPFLAGS' (or '*_CPPFLAGS')
这是不是因为版本不一样,里头有个东西名字改了
Makefile.am在附件里头  应该怎么去改啊
huangxz 发表于 2015-10-26 22:21 | 显示全部楼层
这个东西最好用开发包带的,自己找的很多兼容性有问题的
 楼主| Crazyoncemore84 发表于 2015-10-27 16:53 | 显示全部楼层
好吧,老是被兼容问题搞得头疼:L
mini1986 发表于 2015-10-28 10:57 | 显示全部楼层
不是错误,是警告,应该可以继续下一步吧......
