[PIC®/AVR®/dsPIC®产品] rtcc中断为什么进不去,其他的都正常
904|1
 楼主| zhuanxing 发表于 2015-10-27 09:22 | 显示全部楼层 |阅读模式
RTC, GB, lh, ARM, se
#pragma interrupt InterruptHandlerHigh
void InterruptHandlerHigh (void)
     PIR3bits.RTCCIF=0;
     read();
#pragma code high_vector =0x0008
void InterruptVectorHigh (void)
     _asm
     GOTO InterruptHandlerHigh
     _endasm
#pragma code
void main(void)
        //unsigned int i;
        OSCCONbits.SCS = 3;
        OSCCONbits.IRCF = 7;
    OSCTUNEbits.PLLEN = 1;                          //定义使用内部振荡器
    TRISAbits.TRISA5 = 0;
    DSCONHbits.RTCWDIS = 0;
        ANCON0 = 0XFF;
        ANCON1 = 0X1F;
        T1CONbits.T1OSCEN = 1;
        RTCC_Init();
        PIR3bits.RTCCIF = 0;
        PIE3bits.RTCCIE = 1;
        IPR3bits.RTCCIP = 1;
        while(1)
void unlock(void)
        _asm movlb 0x0F   _endasm
        INTCONbits.GIE = 0;
        EECON2 = 0X55;
        EECON2 = 0XAA;
    RTCCFGbits.RTCWREN = 1;
void setALARM(void)
        unsigned int t;
        unlock();
        ALRMCFGbits.ALRMEN = 0;
        while(RTCCFGbits.RTCSYNC==1);
        ALRMCFG |= 0x02;
        ALRMVALL=0X01;   //day  11日
        ALRMVALH=0X01;   //month 12月
        ALRMVALL=0X00;   //hour 14时
        ALRMVALH=0X05;      //weekday 星期五
        ALRMVALL=0X00;   //second  59秒
        ALRMVALH=0X00;   //minute  39分
        ALRMCFG |= 0x02;
        alarm.day = ALRMVALL;
        alarm.month = ALRMVALH;
        alarm.hour = ALRMVALL;
        alarm.week = ALRMVALH;
        alarm.seconds = ALRMVALL;
        alarm.minutes = ALRMVALH;
        RTCCFGbits.RTCEN = 1;
        RTCCFGbits.RTCWREN = 0;
void setRTCCtime(void)
        unlock();
        RTCCFGbits.RTCEN = 0;
        ALRMCFGbits.AMASK = 0;
        ALRMRPT = 0;
        ALRMCFGbits.CHIME = 1;
        PADCFG1 = 0X00;
        RTCCFG |= 0x03;
        RTCVALL=0X15; //year 0x
        RTCVALH=0X0;
        RTCVALL=0X31; //day
        RTCVALH=0X12; //month
        RTCVALL=0X23; //hour
        RTCVALH=0X04; //weekday
        RTCVALL=0X58; //second
        RTCVALH=0X59; //min 0x
        RTCCFGbits.RTCOE = 0;
        ALRMCFGbits.ALRMEN = 1;
void RTCC_Init(void)
        setRTCCtime();
        setALARM();
为什么中断进不去呢,求高手来看一下,时钟正常,alarm寄存器也写入了,就是在中断进不去?为什么?
 楼主| zhuanxing 发表于 2015-10-27 13:02 | 显示全部楼层
需要配置PEIE = 1;
