PSoC3_FirstTouch STARTER KIT不能编程下载和调试
1434|9
 楼主| HXW718059156 发表于 2015-10-27 09:31 | 显示全部楼层 |阅读模式
我是2010年买的一块PSoC3_FirstTouch STARTER KIT, 最近有个项目想用PSoC3,把这个板子拿出来,下载最新的PSoC Creator  3.3 (3.3.0.410)开发IDE, 但是发现不能编程下载和调试我的这块PSoC3_FirstTouch STARTER KIT了,有人遇到过这个问题吗,如何解决?
附件是我遇到的问题截图(This device is recongnized, but PSoC Creator does not support using it at this time ),请参考!
我的PSoC3_FirstTouch STARTER KIT上PSoC3的part-number 为: CY8C3866AXI-040ES2 0919(我手上有两只样品是CY8C3866AXI-040ES3 1101) 这里面ES2和ES3是表示版本吗? 0919和1101是表示生产日期(2009年第19周和2011年第1周)?
这个问题和芯片的版本有关系吗?
我使用的IDE软件信息:
Environment:
Culture: Chinese (Simplified, PRC)
OS Version: Microsoft Windows NT 6.1.7600.0
CLR Version: 4.0.30319.296
Installed CyInstaller Products:
CY8CKIT-003A Rev*C
Cypress Document Manager 1.0 SP1
PSoC Programmer 3.23.1
PSoC Creator 3.3
Loaded Plugins:
Version: 3.3.0.410
Company: Cypress Semiconductor
Description: Loads component customizers.
Name: Addin Discovery
Version: 3.3.0.410
Description: Discovers PSoC Creator addins (kits, language packs, etc)
Version: 3.3.0.410
Description: Device Catalog Plugin
Version: 3.3.0.410
Description: Adds the topics available in the documentation.
Version: 3.3.0.410
Description: Adds a start page to the framework.
Version: 3.3.0.410
Description: Add a feedback page to the framework
Name: Output Window Plugin
Version: 3.3.0.410
Description: Adds the output window
Version: 3.3.0.410
Description: The Source Code Control Manager is the central class used for SCC actions within PSoC Creator.
Name: Symbol, Schematic and SchMacro Factory
Version: 3.3.0.410
Description: The Symbol and Schematic Factory is used to load, cache, and retrieve symbols and schematics.
Name: Project Manager Plugin
Version: 3.3.0.410
Description: Adds project management related functionality.
Name: File Editor Factory Plugin
Version: 3.3.0.410
Description: Add file editors to the framework.
Version: 3.3.0.410
Description: Loads the Symbol and Schematic editors
Version: 3.3.0.410
Description: Supports user files in multiple languages
Version: 3.3.0.410
Description: The Workspace Factory is used to retrieve instances of PSoC Creator workspaces.
Version: 3.3.0.410
Description: The Project Factory is used to retrieve instances of PSoC Creator projects.
Version: 3.3.0.410
Description: PSoC Creator Toolchain Manager
Name: ARM GCC Generic
Version: 3.3.0.410
Description: ARM GNU Generic
Name: ARM MDK Generic
Version: 3.3.0.410
Description: ARM MDK Generic
Name: ARM IAR Generic
Version: 3.3.0.410
Description: ARM IAR Generic
Name: DP8051 Keil Generic
Version: 3.3.0.410
Description: DP8051 Keil Generic
Version: 3.3.0.410
Description: Adds a dialog that allows the user to select a device.
Name: Transport Framework
Version: 3.3.0.410
Description: Provides a generic device communication framework for use by other plugins.
Version: 3.3.0.410
Description: The Core Debugger provides an architecture independent framework for the common debug features.
Version: 3.3.0.410
Description: Provides debugging support for the different PSoC families through a GDB backend.
Name: Device IO Transport
Version: 3.3.0.410
Description: Provides device IO support for Cypress devices though PSoC Programmer APIs.
Name: Serial Transport
Version: 3.3.0.410
Description: Provides basic serial device support for the rest of the tool.
Version: 3.3.0.410
Description: Provides a host tool to perform bootloading operations.
Name: Background Elaborator
Version: 3.3.0.410
Description: PSoC Creator Background Elaborator.
Version: 3.3.0.410
Description: The TypeCache Factory is used to retrieve instances of TypeCaches.
Version: 3.3.0.410
Description: Registers resource editors with devices.
Version: 3.3.0.410
Description: Enables quick and correct development of applications that use DMA.
Version: 3.3.0.410
Description: Manages custom component tuner executables
Version: 3.3.0.410
Description: The Notice Window displays notices (status messages / errors with managed lifetimes).
zheng522 发表于 2015-10-27 09:35 | 显示全部楼层
找个老版本的Creator来试试
 楼主| HXW718059156 发表于 2015-10-27 09:41 | 显示全部楼层
新版本的Creator也是支持PSoC3的啊?而且新的Creator可用的component要多些,应该也修复了一些bug,更加高效和稳定些
 楼主| HXW718059156 发表于 2015-10-27 09:49 | 显示全部楼层
我查了一下官网最新的part number为CY8C3866AXI-040T,后缀多了一个T是啥意思?datasheet上也没有讲
nolaziness 发表于 2015-10-27 12:42 | 显示全部楼层
我以前遇到了一样的问题,原因是这板子上的芯片是ES版就是非量产的工程试验样片,这个只能用PSOC CREATOR 2.2之前的吧,我没试过。你可以淘宝买一个PSOC3自己手动换一换就可以用新版本的软件了,我的做法是:买了片PSOC5-5868LP换上,再更新下板子上的下载器固件,成了“PSOC5LP FIRST TOUCH KIT”,完美使用中。
给力芯片 发表于 2015-10-27 12:47 | 显示全部楼层
我以前遇到了一样的问题,原因是这板子上的芯片是ES版就是非量产的工程试验样片,这个只能用PSOC CREATOR 2 ...
学习了,还有这个问题
zb0830 发表于 2015-10-27 12:48 | 显示全部楼层
怎么提供工程样片呢,这确实有点坑啊
 楼主| HXW718059156 发表于 2015-10-29 09:23 | 显示全部楼层
非常感谢~!:handshakePSoC5 和PSoC3可以兼容pin to pin吗?
 楼主| HXW718059156 发表于 2015-10-29 09:24 | 显示全部楼层
非常感谢~!:handshake,但是PSoC5可以和PSoC3完全兼容吗?
 楼主| HXW718059156 发表于 2015-10-29 09:25 | 显示全部楼层
怎么提供工程样片呢,这确实有点坑啊
工程样品太不负责任了,忽悠客户啊:@
个人签名:不要看不起别人,要让人家看得起你!never look down upon anyone,but keep yourself
